gacksen Posted February 17, 2020 Share Posted February 17, 2020 Hi Gents, anybody of you running ITB´s in the Z ? Have ditched the triple weber 45´s and setup up the jenveys with an aftermarket ECU and wideband lambda. My question is at what AFR are you aiming at idle / part throttle and WOT ? not sure at what the engine likes so far. Have tuned some honda K20´s with the wideband and had them until 50% throttle at 14.7 and then slowly to 13.0 at full WOT. Maybe somebdy can shed some light ? Quote Link to comment Share on other sites More sharing options...
seattlejester Posted March 1, 2020 Share Posted March 1, 2020 Welcome to the forum, please take a moment to look through the announcement section. We currently have a bug that prevents posts from showing up if punctuation is used in the title. Quote Link to comment Share on other sites More sharing options...
tioga Posted March 15, 2020 Share Posted March 15, 2020 (edited) They tend to like to be richer than 14.7. Mid to low 13’s produce a decent idle. You can lean it out a bit at your cruse and go a little to the rich side at work. What fuel system are you running? Can you just build your VE table and then just change your lambda target and have it adjust your mix? If that is the case at idle you can just try a few different targets and see what I am talking about. Idle will definitely fall off in the 14’s and be happy in the 13’s Edited March 15, 2020 by tioga Quote Link to comment Share on other sites More sharing options...
