280JZFlorida Posted April 11, 2020 Share Posted April 11, 2020 Hey people. Doing a 2JZGTE swap, matched up to a CD00A/CD009 with an OEM Clutch Slave Cylinder VQ35DE, and 6 puck single disk competition clutch. Getting to final details stage and wondering if my stock 1978 280Z clutch master needs to be upgraded to a better match. I see posts replacing with clutch master with willwood 7/8 and swapping out shaft, but I am not sure about the match up on the trans side for my setup. Anyone put a CD009 in a S30 running 500-600 hp with any thoughts? Thanks and stay healthy. Quote Link to comment Share on other sites More sharing options...
NewZed Posted April 11, 2020 Share Posted April 11, 2020 This is the important part. If the pressure plate is the same type as the Z engine, and the fork ratio is the same, there's no good reason to change any of the hydraulics. Slave stroke calculated with fork ratio gives throwout sleeve travel. That's what disengages the clutch. Quote Link to comment Share on other sites More sharing options...
280JZFlorida Posted April 13, 2020 Author Share Posted April 13, 2020 Thanks NewZed! Finally, something I can leave as it is. Quote Link to comment Share on other sites More sharing options...
malibud Posted April 13, 2020 Share Posted April 13, 2020 well bleeding it is tough I had to take the master off an lay it low . I used a willwood master as well Quote Link to comment Share on other sites More sharing options...
