Gas filler recess
I am working on my 76 280z.  The recess behind the gas door was rusted out in one corner.  See pictures below.  I noticed that the backside was seam sealed all the way around.
Where is gasoline or more importantly water supposed to go when it gets in there?  Obviously you don't want to have gasoline leak on the back side of the quarter panel because the smell would be inside the cabin.  Has anyone welded in a nipple in the corner and attached a hose that runs down and empties on the ground?  That's my current plan.
Thanks for any comments
@fusion
hmm... when you hold it up to the car, does it look like water will not naturally drain out the bottom of the gas filler door? would water stay put in that pocket? Instead of putting a nipple in, id just weld-in a sheet of steel to replace the rusted out piece, but angle it in a way that makes sure water does stay trapped in there. It should drain out the filler door.
