1984AEisback Posted March 26, 2021 Share Posted March 26, 2021 Hey there,I’m new to the forums. This is my second 1984Z. I got another one after having one along time ago. Anyway, it’s only got 60,000 miles on it and when you shift in and out of gear putting a load on and taking a load off of the transmission and drive line, there’s a clunk both engaging and disengaging unless you do the clutch insanely slowly and perfectly - Which is not close to normal driving. I’ve narrowed down that the clunk sound is coming from somewhere underneath the shifter.we thought it was on the rear of the car. The car now has a new driveshaft, new clutch, new fly wheel, transmission oil changed, new subframe bushings, new differential mount/insulator all done professionally by a mechanic that’s very experienced. The mechanics aren’t sure what to look at next. I jacked The rear end up to get the wheels off the ground and put it in gear and put the clutch on and off to determine that the sound was coming from somewhere under the shifter (mid area) of the car rather than something at the back. Any ideas? Thank you Quote Link to comment Share on other sites More sharing options...
1984AEisback Posted March 26, 2021 Author Share Posted March 26, 2021 Here are the 3 videos I took under the car trying to narrow down the noise: (25 seconds) https://drive.google.com/file/d/1AjQ4Kvh4eN__tr288uVKkHLbBUymNt8B/view?usp=sharing (31 seconds) https://drive.google.com/file/d/1_22FuTzPmCNFyJcUcdT6q7TAR0_lbtb0/view?usp=sharing This one points to the sound as best as I can tell. (24 seconds) https://drive.google.com/file/d/18otKlGipECdSjlBNsbwYzFvELL9bxu4H/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
Mayolives Posted March 26, 2021 Share Posted March 26, 2021 Did you take a close look at the old gear oil that was drained from the gear box? Was any metal visible in the drain pan? Have you checked the half shafts for play in their u-joints? Quote Link to comment Share on other sites More sharing options...
1984AEisback Posted March 26, 2021 Author Share Posted March 26, 2021 Thanks for helping. We did drain it and there was nominal small shavings according to my mechanic but nothing that he thought was unusual. I am not sure if they’ve checked for play in the half shafts. We will check that. Thank you Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted March 26, 2021 Share Posted March 26, 2021 On 3/26/2021 at 2:01 AM, 1984AEisback said: Hey there,I’m new to the forums. This is my second 1984Z. I got another one after having one along time ago. Anyway, it’s only got 60,000 miles on it and when you shift in and out of gear putting a load on and taking a load off of the transmission and drive line, there’s a clunk both engaging and disengaging unless you do the clutch insanely slowly and perfectly - Which is not close to normal driving. I’ve narrowed down that the clunk sound is coming from somewhere underneath the shifter.we thought it was on the rear of the car. The car now has a new driveshaft, new clutch, new fly wheel, transmission oil changed, new subframe bushings, new differential mount/insulator all done professionally by a mechanic that’s very experienced. The mechanics aren’t sure what to look at next. I jacked The rear end up to get the wheels off the ground and put it in gear and put the clutch on and off to determine that the sound was coming from somewhere under the shifter (mid area) of the car rather than something at the back. Any ideas? Thank you Expand I use a 3'-4' piece of garden hose as a stethoscope. You'll be able to poke it into tight areas while holding it to one ear and pinpoint the sound. I noticed the transmission twitching in unison with the click clack noise. Be sure to check that for the source of the problem. Quote Link to comment Share on other sites More sharing options...
1984AEisback Posted March 26, 2021 Author Share Posted March 26, 2021 Thanks!! I’ll try that too Quote Link to comment Share on other sites More sharing options...
silverado22c Posted March 29, 2021 Share Posted March 29, 2021 Buy a cheap mechanic's stethoscope from Harbor Freight or similar place, only $5. You can hear the gears grinding after engaging gear, that low grind. The clunk is probably something to do with the syncros, gears or something else internal to the transmission. I don't have any personal knowledge on these transmissions, just your video pointing to most likely the transmission. Maybe a gear shaft bearing is worn, not allowing gears to be properly meshed. Quote Link to comment Share on other sites More sharing options...
