Vacuum switching valve / top gear switch removal question
Coelocanth81
I have a '76 280z that has received a 5 speed swap prior to my owning it. Did the 5 speed transmissions even have a "top gear switch" for the purpose of advancing the distributor?  I'm thinking about removing the vacuum switching valve when I rebuild my fuel rail.
Actually, 76 does have a top gear switch actuated solenoid that controls the vacuum to the vacuum advance module on the distributor.  One of those emissions things.
There are a lot of different 5 speeds out there.  Some of the ZX 5 speeds have neutral, top gear, reverse, and overdrive switches, at least the FSM says they do.
I removed my top gear solenoid when I got a 5 speed and just let the vacuum advance happen in all gears.  Ran great.  Just connect the hoses or run a new one to the same port on the TB.
I think I've seen it described somewhere in the FSM but can't find it.  It's in the wiring diagram also though.
Underlined the two parts connected.
Edited by NewZed
