GTOpete Posted July 23, 2023 Share Posted July 23, 2023 I have a idling problem on my car where after its warmed up the rev the car idles at about 2100 revs and should be at about 800. Many have said is a air leak somewhere. I have attached pics of my engine and airflow system. Also here is what someone has written on another forum, they said I should as the experts here. You need to know what computer is running it. Since it is individual throttle bodies it probably uses an alpha- N fueling setup ( no map or MAF sensor ) with alpha-N setups it's all based on the TPS ( throttle position sensor ) this may have gotten moved or tweaked and needs to be reset in the computer so that it fuels the idle properly. Some of these setups do have IACs and some do not ( idle air control ) without knowing the setup and the computer it's hard to know for sure what the issue is. Also if someone knows the parts used here so can find new ones. It says the parts are Nissan but no number Any suggestions? Thank you Pieter Quote Link to comment Share on other sites More sharing options...
clarkspeed Posted July 24, 2023 Share Posted July 24, 2023 (edited) Need some more details to troubleshoot. Did it idle good before? What changed? What EFI computer? Do you have an O2 readout? What kind of TB/intake manifold is that? Also agree with your other post. Edited July 24, 2023 by clarkspeed Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted August 1, 2023 Share Posted August 1, 2023 Those throttles are interesting! Quote Link to comment Share on other sites More sharing options...
