christianmoller Posted January 24 Author Share Posted January 24 Good evening, I now have a working two speed PWM controlled C7 fan. I used an Arduino to create a PWM signal at 50 percent(LOW) 90 percent (HIGH) and some slope up/down between the different stages. I added a voltage regulator i had around when fixing my dodgy gauges on the Datsun (LM7810). /Christian Quote Link to comment Share on other sites More sharing options...
Box5 Posted April 8 Share Posted April 8 Very nice build so far, looking forward to your updates as you go. Quote Link to comment Share on other sites More sharing options...
christianmoller Posted April 9 Author Share Posted April 9 (edited) It has been a very slow progress for a couple of months unfortunately but i hope to take a test run this summer. Edited April 9 by christianmoller Quote Link to comment Share on other sites More sharing options...
christianmoller Posted 16 hours ago Author Share Posted 16 hours ago hello, Some tiny small steps right now. I have started with the frame rails and have made the part that will go inside the car. 1.5mm steel that goes front to rear. New ones under the car are being made with a higher profile than standard, 45mm in front and 25 in the rear. Christian Quote Link to comment Share on other sites More sharing options...
