Yet another LS 260z swap :)
Good evening,
I now have a working two speed PWM controlled C7 fan.
I used an Arduino to create a PWM signal at 50 percent(LOW) 90 percent (HIGH) and some slope up/down between the different stages.
I added a voltage regulator i had around when fixing my dodgy gauges on the Datsun (LM7810).
/Christian
  • 2 months later...
hello,
Some tiny small steps right now.
I have started with the frame rails and have made the part that will go inside the car.
1.5mm steel that goes front to rear.
New ones under the car are being made with a higher profile than standard, 45mm in front and 25 in the rear.
Christian
  • Like 1
Crazy Scandinavians🤣.
My intension was to have 65mm in profile height but then it starts to "eat" on ground clearance so i got the idea from my old Mercedes C43 were most reinforcement were on the inside , probably to get a flat underside.
/Christian
Posted (edited)
good evening :)
frame rails are done and also some reinforcement to the transmission mount,inspector wants it).
He will visit June 16 for the first inspection and after that i have five years to build for the final inspection were he wants to see a working vehicle.
i also start with the carpet and sound deadening as i wait for him.
Clutch is in the mail and only waiting for the half shafts to be made :).
A new props shaft is made, for the first time i bought a new one instead of building my self(want a proper made one:))
/Christian
image.jpeg.054c0af845de9abd0d437710e5ecdf3b.jpegimage.jpeg.50a1e6b3c54ac805be420d452c325be4.jpegimage.jpeg.dfde0565efd089f842403ca7c7d08a4b.jpegimage.jpeg.a42a74b75b4561e6fe0fbf8564c9ac43.jpegimage.jpeg.bd2041094130680f871d080cd3f4b15b.jpeg
Edited by christianmoller
  • Like 1
Posted (edited)
I went to Sweden about 15 years ago, and at night we asked people wheres a good place to go in Stockholm. I guess it was after midnight, and several people said Applebees of all places. I thought that was weird until I got there. It was packed, then then I saw why. People were street racing all kinds of crazy stuff that you could see from the outside tables. I saw everything from a  Lambo race a 4 wheeler to a ferrari racing a street bike. It was kind of wild.
Edited by socorob
Good evening gents :)
I got my first inspection cleared with some minor things to fix so now i have five years to finish the build (he  wanted to see me at the end of August :) ) .
With that done i was able to pain all the weld, start interior work and mount the Datsun back up again, sooooo, it's done just waiting for my half shafts.
The half shafts is actually the only thing that keeps me from a test run.
Brakes, clutch are bled, emergency brake mounted, it's pretty much only interior work that has to be done :)
Cheers
Christian
  • Like 1
