FastFloridian Posted June 21 Author Share Posted June 21 (edited) 2 hours ago, jhm said: You probably already know this; but most folks like to add a good amount of bracing to the steering shaft bracket/mounting. The additional weight of the electric motor mechanism can cause flex in the stock mounting bracketry. Easier to add the bracing now, when you've got the interior stripped vs later. Are you sure you want this additional weight & complexity in your dedicated track car? In addition to that, some of the power steering systems induce a vagueness in the steering feel, particularly near-center. I’m new to this platform so I don’t know anything, lol, appreciate the advice. I’ll add some bracing. I’m planning to run some big sticky tires up front, figured the assistance would be needed, this system has a dial to vary the level of assistance. We’ll see, can always switch back, I’ll hold onto the existing column for a bit just in case. Edited June 21 by FastFloridian 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted June 22 Share Posted June 22 make sure you reinforce the sway bar mounts in the front. 1 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted June 28 Author Share Posted June 28 On 6/22/2025 at 2:04 AM, A to Z said: make sure you reinforce the sway bar mounts in the front. Thanks, just ordered sway bar plates from bad dog Quote Link to comment Share on other sites More sharing options...
A to Z Posted June 28 Share Posted June 28 GREAT! I haven't seen those....I got mine from Z car depot. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted July 26 Author Share Posted July 26 Started learning to weld, here’s my first tries last weekend and through today, about ready to weld on the car. Going to practice on some thinner stuff first to get more practice. 1 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted July 26 Author Share Posted July 26 Started cutting on the dash to see how it will fit, roll cage goes through it. Now I need to mock up the digital gauge display and see how it will fit. Displays is bigger than dash think it needs to Poké above dash as steering column looks to sit too close below. Too hot out, done for the day. Quote Link to comment Share on other sites More sharing options...
Apex Posted July 28 Share Posted July 28 On 3/2/2025 at 12:18 AM, A to Z said: looks like you have a good start on it. My concern would be the rails. they made need to be patched, and using a V8, and modified at that, BEEFY rails would be a good idea. Some guys have even using thick steel runs of pipe that are U channel . I attached pics of my car and some of the patching done. MY car had 45K original miles and 30 years of its life sitting in an airplane hanger and I STILL had to fix the rails. I attached a close up pic I got from one of your pics, and it already looks like it needs attention. here is a link to watch : Just randomly reading through some build threads on here and see my video linked lol Those are some massively wide rear quarters you're using @FastFloridian. Crazy stuff. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted July 29 Author Share Posted July 29 23 hours ago, Apex said: Just randomly reading through some build threads on here and see my video linked lol Those are some massively wide rear quarters you're using @FastFloridian. Crazy stuff. Nice, cool to see you didn’t waste your time making that video. Probably running 325s on the rear, and maybe even all around (still a lot of time before I need to decide on that), I’ll need those wide fenders to fit all that rubber. Quote Link to comment Share on other sites More sharing options...
A to Z Posted August 3 Share Posted August 3 sure is a different looking dash! Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted August 4 Author Share Posted August 4 7 hours ago, A to Z said: sure is a different looking dash! Going with a holley digital dash, this offered a blank canvas. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted August 4 Author Share Posted August 4 Got on the wire wheel and went to town on the engine bay and front fender wells, prepping for paint. Need to wash it down and go over it one more time. Test painted a few spots. Also got the fender braces on, but not fully welded. Started getting a hole in the body panel, so decided to tac it and fully welded it later after some more practice, probably start practicing tig, need some gas first. 1 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted yesterday at 02:53 PM Author Share Posted yesterday at 02:53 PM Did final scrapping and cleaning of engine bar and fender area. Dried and going to get first coat of paint on today or tomorrow. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted yesterday at 02:55 PM Author Share Posted yesterday at 02:55 PM Got more goodies in, front and rear bad dog frame rails and a steering wheel mount for my Holley digital dash. Not sure if I’ll use it, but think it’s a viable option. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted 2 hours ago Author Share Posted 2 hours ago All painted. Going to do another coat of semigloss for the engine bay, but frame/fenders are ready for suspension 😁 I’m hoping to start next weekend 1 Quote Link to comment Share on other sites More sharing options...
jhm Posted 2 hours ago Share Posted 2 hours ago Looking good. Seems like that's always some of the most rewarding parts of any resto....getting all those hard-to-access areas cleaned up, rust repaired, straightened/strengthened/reinforced, and freshly painted. 👍 Quote Link to comment Share on other sites More sharing options...
