Posted (edited)
2 hours ago, jhm said:
You probably already know this; but most folks like to add a good amount of bracing to the steering shaft bracket/mounting.  The additional weight of the electric motor mechanism can cause flex in the stock mounting bracketry.  Easier to add the bracing now, when you've got the interior stripped vs later.
Are you sure you want this additional weight & complexity in your dedicated track car?  In addition to that, some of the power steering systems induce a vagueness in the steering feel, particularly near-center.
I’m new to this platform so I don’t know anything, lol, appreciate the advice. I’ll add some bracing. I’m planning to run some big sticky tires up front, figured the assistance would be needed, this system has a dial to vary the level of assistance. We’ll see, can always switch back, I’ll hold onto the existing column for a bit just in case.
Edited by FastFloridian
  • Like 1
  • 4 weeks later...
Started cutting on the dash to see how it will fit, roll cage goes through it. Now I need to mock up the digital gauge display and see how it will fit. Displays is bigger than dash think it needs to Poké above dash as steering column looks to sit too close below. Too hot out, done for the day.
On 3/2/2025 at 12:18 AM, A to Z said:
looks like you have a good start on it.  My concern would be the rails.  they made need to be patched, and using a V8, and modified at that, BEEFY rails would be a good idea.  Some guys have even using thick steel runs of pipe that are U channel .  I attached pics of my car and some of the patching done.  MY car had 45K original miles and 30 years of its life sitting in an airplane hanger and I STILL had to fix the rails.  I attached a close up pic I got from one of your pics, and it already looks like it needs attention.   here is a link to watch :
Just randomly reading through some build threads on here and see my video linked lol
Those are some massively wide rear quarters you're using @FastFloridian. Crazy stuff.
Nice, cool to see you didn’t waste your time making that video. Probably running 325s on the rear, and maybe even all around (still a lot of time before I need to decide on that), I’ll need those wide fenders to fit all that rubber.
Got on the wire wheel and went to town on the engine bay and front fender wells, prepping for paint. Need to wash it down and go over it one more time. Test painted a few spots. Also got the fender braces on, but not fully welded. Started getting a hole in the body panel, so decided to tac it and fully welded it later after some more practice, probably start practicing tig, need some gas first.
  • Like 1
Looking good.  Seems like that's always some of the most rewarding parts of any resto....getting all those hard-to-access areas cleaned up, rust repaired, straightened/strengthened/reinforced, and freshly painted.  👍
  • Thanks 1
Heat advisory today, and I believe it, damn it’s hot. Started off replacing studs with APR extended studs then attaching 370Z wheel bearings to the custom spindle, did all that in the AC. Then to the outside, unboxed all the front suspension and got subframe, new plate for control arms and upper control arms up. Stupid plate was near impossible to install. It’s perfectly shaped to frame, bolt holes don’t align when carriage bolts are up, and plate doesn’t align and fit on when carriage bolts are down. Took forever halfway adjusting it, having my dad tap carriage bolts from top while I’m holding and aligning from bottom. Nightmare, but finally got it on. Hopefully the rest will go smoother. Did I mention I’m exhausted
  • Like 1
Got a few more things on today. This kit has tons of adjustability, just making some initial guesses on caster, bumpsteer, etc. a little bit of a puzzle with the hardware, some things you only needed if keeping stock subframe or other stock parts. I hope to have the rest installed next weekend.
  • Like 1
