running lean?
DAT240Z
I know what you are talking about. The stock Zx fuel injection has a switch over point where the injectors go from about 40 percent duty cycle to 85 percent or whatever it goes to. Once it switches, it pulls really good.
Make sure you clean the connections at the ECU very well, and then you need to start doing some tweeking with the AFM, timing, etc to make it better. Maybe raise your fuel pressure a little bit.
I notice that the car pull good to 3-3500 rpm, than it seams like it running
lean not much power than around 4krpms it take off and pulls all the way to
the red line, when does boost kicks, somehow I was thinking around 3k is
when it should kick in. I just clean all my connectors. is there to check and see if i'm running lean around 3-4k rpm.
What ECU/airflow system are you running? Is the engine/fuel system/turbo stock? Are you running stock boost levels? Any more information about what you are running will help - any changes you may have made could be important.
Do you have good gauges, such as a boost gauge and an air/fuel mixture gauge? These can be invaluable towards diagnosing EFI and turbo issues.
