Chevy 350 Auto to Manual transmission swap
So I have a chevy 1998 V8  4 bolt 350 small block with a carburetor. Currently I have a 3 speed automatic and I'm not sure what transmission it is, but I want to swap into a manual. I just want to daily and be able to drive on highways. What are the manual transmissions I can use to fit into my 1972 240z?
1989 Camaro T5 mated to SBC 350
Basics
1. T5 transmission:  The 1989 WC T5 transmission is tilted 15 degrees towards the driver.   The 15 deg tilt is absolutely no problem, I have done two just cut away the trans tunnel as in the picture below. The tilt is not noticeable once center console is installed. Unless you want to make a special transmission mount, you will need an 89 Camaro T5 bell housing, driveshaft, flywheel, clutch pressure plate/disk, throw out arm, throw out bearing, clutch slave and a 7/8" clutch MC.  Note that there is a V8  and a V6 version of the T5 transmission. They have different spline counts.  You will need the V8 version.
2. Bell Housing:  1989 -90 bell housing for V8. Verify that the pivot ball is in place as that part is NLA.
3. Flywheel: 158 tooth flywheel:  https://www.summitracing.com/parts/zzz-50-6516
4. Clutch Kit: Zoom High Performance Clutch Kits HP1675-1A https://www.summitracing.com/parts/zzz-hp1675-1a/applications/
5. Clutch Hydraulic Components:
6. Clutch Hose and Fittings:
6. Starter: Hitachi gear reduction starter or similar unit.
7. Complete 240z brake and clutch peddle assembly swap.
8 MSA/JTR transmission mount
See my post of 12 June 18 second post down  lots of pictures
Edited by Miles
  • Like 1
Buy this book first
There are a lot of details about the 240Z V8 auto to manual conversion you need to know before you start the project.
Purchase and read the JTR V8 conversion manual. You can buy it here: https://jagsthatrun.com/collections/jtr-v8-conversion-manuals/products/copy-of-v-8-conversion-manual-for-volvo-200-series
  • Like 1
