What adjustable FPR are you using?
SleeperZ
I am planning my MAF/injector upgrade. I intend to remove the sensor wire from the MAF and install it in a 3.5" intake pipe. This will let in 40% more air for the same MAF reading. Then I will install the browntop SVO injectors (40% more fuel than stock). This may work with minimal adjustment, but any fine tuning I need to do, I'd like to do with an adjustable FPR.
So who is using an adjustable FPR that is reasonably priced, has a good adjustment range around the stock pressure of 36 psi (ie: goes lower and higher), and will regulate at flows up to 50-60 gallons/hour?
Is this one overkill? Aeromotive
i have a paxton regulator, works fine. you wont find one that will go below 30 PSI AFAIK. Nathan try MSD, part number MSD 2222 it sells for 50 bucks at summit. go to summits sight and do a search for that msd part number. they do stock it, only they dont advertise it. you have to search for it. raises presure at a 1:1 ratio.
The price is certainly right, but my concern with the MSD is (as was mentioned on another recent post) is the flow rating. 9-10 gallons per hour is not a reasonable flow rating - heck, the nissan factory regulator obviously flows at least 4 times that, so it is hard to believe the MSD would suck so bad. I guess I will call their technical support and try to get the skinny.
