carb conversion 240 on 260
since so many people have told me the flat top carbs are crap and since i cant get mine to stop shooting gas into the air filter i was wondering how hard it would be to put 240 round top carbs on my 260. do i only need the carbs or also the intake manifold, also what kind of problems would i run into regarding the vacum lines, as im assuming the 240 has fewer than the 260.
fairlady 327 did it with just the round carbs on a 74, of course its ugly as hell with plugged vacum lines- but it was worth at least 10hp over those rotten flattys.
On my first '73 240Z I swapped the entire intake, carb's and linkage from a '72 240Z.
('73's have same basic carb. setup as '74 260Z's)
It was very easy to do. Only took an hour or so, and it worked perfectly.
There are several early SU setups on eBay to choose from.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1843906331
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1843588245
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1842754558
I agree with Bang. I didn't know the early SU's were so common or cheap.
One word of caution. You need to make sure the carbs you are getting are rebuildable. The throttle shaft bushings tend to wear causing a lean condition at idle.
I had just this problem on my 70. The lean condition caused some pinging which required me to use high octane gas. I found a place in LA that said they could replace the bushings, but it was going to run $500 or $600 to do. For that price it made more sense to get the smog leagal dual Webers from MSA.
If I had it to do over again, I probably would have rebuilt the SU's. The Webers are nice carbs (a progressive 2 barrel with an honest to god accelerator pump), but the J bend adaptors to plumb them into the sidedraft intake manifold tends to puddle fuel when idling with a cold engine. Besides, the SU's are just too cool.
FYI. MSA sells "rebuilt" SU's on an exchange basis for $600. You could buy one of the ebay set ups to get the carbs and all needed linkage. Once they are installed and tuned correctly, spray some starting fluid around the throttle shaft bushings. If you see a change in idle speed, then the carbs need to be rebuilt. You could then use them as cores for the MSA exhange (or find a local shop that can do the work for you).
i checked out ztherapy, not only was it confusing but the product that it looked like i needed was 900 bucks, i dont have that kind of cash and if i did i wouldnt worry about the carbs because there would be a 350 sitting there. i appriciate all the info though, even though i hardly understand any of it, i just want to get the thing to stop flooding so i can sell the car.
No, all you need to get from Z therapy are the rebuilt carb bodies for 175 bucks, maybe the sm needles and new nozzles, and the video. Then transfer all your stuff from the su's over to the new Ztherapy bodies and go.
The 900 deal is the whole shooting match, and they are charging that becuase they are doing all the leg work. Buy a set on ebay or whatever, with the whole setup, and then go from there. Then just bolt the carbs on your manifold, and keep the 240 one for a spare.
You may not need to rebuild the carbs yet. Watch the video and you will become an expert at messing with SU's in a hurry.
I am waiting for my nice K&N's to get here and then I am going to find some velocity stacks to go in there. I have the 260 intake too.
  • 3 weeks later...
Hi Dangerboy,
I've recently done this carby swap myself also, as the flat tops in my '77 260Z kept squirting fuel out of the front nozzle also.
I used the complete intakes and carbies that I took of my '73 240Z engine. Try and get a complete setup, that way there is no messing around, just bolt up the intakes to the head then some fuel lines to the fuel bowl of the SUs, then it should all be sweet (after you tune the carbs!!!)
Something that others haven't said, I found that I needed the metal rod which links the throttle from the carbs to the firewall from a 240Z as this bit is actually longer that those on the flat tops.
As for the pollution gear, all that can stay off as the 240Z set up doesn't need it!!!
You may also need to get a plug to block up the hole in the exhaust manifold if you are using the 260Z manifold and taking of the pollution gear.
Good luck.
