Guest umm Posted December 29, 2002 Share Posted December 29, 2002 I have a fuel pump that makes a lot of noise all the time when the engine is running. Is this common or should I start looking for a new fuel pump? I have a 76 280 w/efi (stock) Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted December 30, 2002 Share Posted December 30, 2002 I do not know about the stock fuel pump but the holley blue pump I have makes a bunch of noise. Wrapped it with rubber tubing to quiet it down some. Mike Quote Link to comment Share on other sites More sharing options...
Ray Posted December 30, 2002 Share Posted December 30, 2002 define alot of noise ???? The stock pumps do make some noise but if if it is more than a hum I would look for another pump. One of the best solutions I have seen latly on modified cars is to do what the MFG's have done and put the pump in the tank. Makes it a lot quieter and depending on what type of FI you are running the pumps are a lot cheaper than a stand alone type pump. I have seen several of the GM TBI pumps used on carb settups with the really good bypass type regulator or fuel log. They put out 8-12psi and will flow some fuel. Good luck...... Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 30, 2002 Share Posted December 30, 2002 mine makes a real loud hum, but i like it! not stock though, porsche 911 turbo pump offroad spec, pumps!!! Quote Link to comment Share on other sites More sharing options...
Two40MuscleZ Posted December 30, 2002 Share Posted December 30, 2002 Mine humms too! It's kinda like a B-52 making ready for take off! Gotta love it though. The idea about isolating the pump in an enclosure is a great one. I will have to give that one some thought. Comps, VAN Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 30, 2002 Share Posted December 30, 2002 Try the radiator mounts from Mercedes. They are 2 studs joined by a rubber insulator. That will at least preclude any of the vibration from getting to the chassis. Tim Quote Link to comment Share on other sites More sharing options...
blueovalz Posted December 30, 2002 Share Posted December 30, 2002 Carter (carbs) sells kits that include 3 isolators very similar to the Mercedes ones mentioned above. the studs are a 10-32 with a rubber cylinder (about 3/4" in dia and about 3/4" long) vulcanized between the two studs. I cut the noise level down on my Holley pump to about 1/2 the level it was before. Quote Link to comment Share on other sites More sharing options...
Guest umm Posted January 1, 2003 Share Posted January 1, 2003 Thanks for the input guys. It's a stock fuel pump, looks like original equipment. It makes a sustained humming noise so on your advice I'll start shopping for something else. Thanks again! Quote Link to comment Share on other sites More sharing options...
