Source for Internal Balance 153 tooth Flywheel...
Check CAT
http://www.catpep.com/
They used to have their price list up, but I couldn't find it last week. For example, they have their SFI certifiedl steel balancer listed for under $100 last month. Great prices, at least they were...
Their stuff was in one issue of the Summit catalog last year, then disappeared. Don't know what was up with that, but I've seen mentions other on the 'net or in magazines with buildups using their parts.
Somebody correct me if I'm wrong but aren't all chevy small blocks internally balanced except for the 400.
I pulled my from a 305 camaro together with the 5 speed. It bolted right up to my 350. It's a work in progress so I don't know how it's going to work. It did come with the 10.4 inch clutch.
Louie.
From GM, all SBC and BBC were internally balanced. Until the arrival of the 400 and 454, both in 1970. In 1986 when GM switched to the one piece rear main seal, they eliminated the counterweight from the back of the crank. This meant that they had to add a counterweight to the flywheel, so all SBC post '85 are MOSTLY internally balanced, save for a counterweighted flywheel. The 400 used a damper that was not zero balanced and so did the 454.
