denny411 Posted February 25, 2003 Share Posted February 25, 2003 What is the maximum diameter of fluid damper I can use with the JTR style conversion? I seem to remember someone saying that there would be clearance problems with an 8", but I couldn`t find any info in my search. Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted February 26, 2003 Share Posted February 26, 2003 I'd recommend a 6.25" to avoid cross member clearance issues. Mark Quote Link to comment Share on other sites More sharing options...
denny411 Posted February 26, 2003 Author Share Posted February 26, 2003 I may have to move the engine forward an inch or so. Would that make any difference in clearance? Quote Link to comment Share on other sites More sharing options...
Cable Posted August 13, 2004 Share Posted August 13, 2004 I too have built a 383 w/ the 8" damper. I planned on buying the JTR kit tomorrow. Is there anything I can do to "space" the engine alittle higher with the JTR kit in order to get the required clearence? Thanks guys!!! Quote Link to comment Share on other sites More sharing options...
jt1 Posted August 13, 2004 Share Posted August 13, 2004 I have a 6 1/4" damper, and in the JTR position, have 3/8 to 1/2" clearance to the steering rack. So an 8" isn't gonna work without spacing the motor up. You could probably add some spacers and raise it a little, with hood clearance in mind. Moving the engine forward makes it worse. John Quote Link to comment Share on other sites More sharing options...
Mikelly Posted August 13, 2004 Share Posted August 13, 2004 I've got my Fluidamper at home (I'm at work) and I'll give tyou the partnumber for it this afternoon... You can NOT use anything bigger than 7.25 inches if memory serves. Mike Quote Link to comment Share on other sites More sharing options...
Cable Posted August 13, 2004 Share Posted August 13, 2004 Well crap. It never crossed my mind about the damper size when I was ordering all the parts for the thing. I guess I'll end up bitting the bullet and forking the money over to get a 6.75" damper. It isn't so much about buying the thing, its that I just REALLY hate re-installing dampers on motors. I know I should break down and buy a damper installer tool, but I always end up using a rubber mallet until I can start the threads on the bolt and have it pull the damper the rest of the way on. The other thing that sucks about that is my timing chain cover has the timing mark tab just for the 8" damper, and I didn't want to remove my water pump or the cover if I could help it. I guess I could buy a bolt-on timing marker, then I wouldn't have to remove the water pump or the timing cover. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted August 13, 2004 Share Posted August 13, 2004 Go to your local parts store and borrow a damper installation tool. DON'T hammer it on! Do you have the JTR manual? It discusses damper sizes... Quote Link to comment Share on other sites More sharing options...
Cable Posted August 13, 2004 Share Posted August 13, 2004 Go to your local parts store and borrow a damper installation tool. DON'T hammer it on!Do you have the JTR manual? It discusses damper sizes... I do not have the JTR manual, its being ordered though. Oh, it isn't like I am wailing away at the damper with a hammer. I just tap in a circle with a rubber mallet until the thread can be caught by the damper bolt. Trust me, I would just the loan install tool, but my 'local' autoparts stores either don't have them or they are too stupid to know what it is (both totally possible) in order to give it to me. Quote Link to comment Share on other sites More sharing options...
jt1 Posted August 13, 2004 Share Posted August 13, 2004 EZ fix on the timing pointer: Fab up a pointer from AL, bring the piston to TDC and mark the pointer. This is a lot easier before you put on the heads. John Quote Link to comment Share on other sites More sharing options...
Datsun660z Posted August 14, 2004 Share Posted August 14, 2004 Just wanted to give a link to A good place to get dampners and other parts. http://www.parts123.com/PartFrame.asp?ZTM=cadegeca&GHOME=www.dirttrackthunder.com&TITLE=Dirt_Track_Thunder Quote Link to comment Share on other sites More sharing options...
Cable Posted August 14, 2004 Share Posted August 14, 2004 Just wanted to give a link to A good place to get dampners and other parts. http://www.parts123.com/PartFrame.asp?ZTM=cadegeca&GHOME=www.dirttrackthunder.com&TITLE=Dirt_Track_Thunder Thanks, luckly I have found out about those guys awhile ago. Great prices and fast shipping. I bit the bullet and have a new 6.75" damper on the way. Thank you for the link anyway. Quote Link to comment Share on other sites More sharing options...
