240 sx TB upgrade question
ToplessZ
  zline said:
make sure u get a 1" spacer so you can use your stock linkage
BTW...My machinist can supply these adapters for the following $$$$:
Billet Aluminum: $45 plus shipping
Cast Aluminum: $20 plus shipping.
I got the cast one and will post a picture if you like.
Tim
  • 4 weeks later...
  280Zen said:
Sorry I meant issue as how will the ECU handle the increase in airflow? will stock injectors push enough fuel to offset the increased airflow? issues along that line.
The airflow meter measures the air - it will measure more, and fuel the extra air appropriately. The throttlebody by itself is not that big of a restriction. If you want lots more airflow, port the head, get a cam and a programmable fuel computer without an airflow meter - that you will need bigger injectors for. The stock injectors are good for 160-180 hp easy.
