Ball and Joints
Guest Pegasus76
to take out the balljoint you will need to remove the 4 bolts holding it to the control arm (2x12mm, 2 of them also hold in the trailing arm - 14mm), and disconnect the two big bolts holding the strut to the steering knuckle. There will be a 19mm (3/4") castle nut with a cotter pin holding the steering knuckle to the balljoint. you can use a pickle fork to separate the two if you have no concern for the balljoint and planning to throw it away.
  • 11 months later...
Guest bluex_v1
Maybe I should know this somehow, but once you get a new strut-bottom balljoint installed in the control arm, how in the world are you supposed to torque the steering arm down with the 19mm nut on the balljoint shaft???
I got mcquay-norris balljoints and they came with a nylock nut instead of a castle nut. I get that thing down to the nylon and the whole shaft part spins around with the nut. What am I supposed to do here?
Impact Wrench! Most of the time it will stop turning once it starts to press into the tappered part of the shaft. Just get it snugged up and then you can torque it down and install the cotter pin!
Guy
Guest bluex_v1
Man, these balljoints are kicking my ass :evil: I will try the impact wrench shortly, but first can someone confirm torque specs for the two short bolts that hold the balljoint to the control arm? My Nissan shop manual says 44-51 ftlbs, however I have broken both a new bolt that came with the ball joint and one of the originals right about at 40 ftlbs. My chiltons manual says 45 ftlbs. Maybe the new bolts are cheap pieces of crap and the old ones were just fatigued???
Also the damn rubber boot is getting pinched kind of unevenly between the balljoint 'frame' and the bottom side of the control arm. Is it supposed to be like this? I'm worried about unnecessary play because of it, and maybe it is making the bolt angle just enough to snap? I dunno. :?:
Guest bluex_v1
Scratch 2 more new bolts, both broke between 40 and 45 ftlbs. The bolts that came with the balljoints are marked '10.9', which is the strongest bolt typically available from what I've read.
All I could find available tonight were some stainless bolts marked 'A-2', which have a tensile strength of about 550MPa, vs about 900MPa of the '10.9' bolts that came with the balljoints.
I have checked my torque wrench against another torque wrench and they are both in agreeance with each other.
I pulled the rubber boot off and tried again so I could be sure that the balljoint frame was sitting flush with the bottom face of the control arm and still snapped a bolt.
What the $*@#?
Guest bluex_v1
Ok, got some new bolts (which had 13mm heads oddly enough, instead of the normal 12mm) and put them on at 30 ftlbs with red locktite. Everything is assembled and just begging for me to get the wheels put on!
Thanks guys. :D
Guest 81na ZX
Semi-related ball joint problem here:
I had no problems getting the joint installed into the CA, or the steering arm on (Nyloc nuts), but I can't get the darn strut to compress enough! It was kicking my butt, so I've let it sit a few days ;)
If I understand your problem correctly then I suggest disconnecting the swaybar, which will allow you to drop the control arm down farther below the strut.
Jon
