Guest thepenguin99 Posted April 11, 2003 Share Posted April 11, 2003 Ok, I am considering getting 215/45/17 tires instead of 215/40/17 tires because of the load rating difference. I originally wanted the 40 series because the diameter would be smaller (23.9"). I also have no idea what the original tire diameter was for my 240z. My question is do think the 45 series tire (24.6") would make my car look jacked up? Also, do you think it will fit without any problems using the stock front valance? thx Nathan Quote Link to comment Share on other sites More sharing options...
z ya Posted April 11, 2003 Share Posted April 11, 2003 Is your car lowered?? My front tires are 24.7 tall and I think it looks just right. It is lowered 1" in the front. The 45's will help fill the wheel well so that you dont look like you have a bunch of air space over your tires. Quote Link to comment Share on other sites More sharing options...
Guest thepenguin99 Posted April 11, 2003 Share Posted April 11, 2003 My car isn't lowered but I plan on lowering it ~1" when I freshen up the suspension. After reading some of the archives it seems that the 45 series tires might even be a better choice than the 40s height wise. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted April 11, 2003 Share Posted April 11, 2003 Yes, the stock diameter is close to 25". 195/70/14 and 205/60/15 are stock tire sizes - I believe the diameters are around 24.9". Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted April 11, 2003 Share Posted April 11, 2003 I'm running 245/50/15 (street tires), and 245/45/16(autocross tires). Both sets are 24.7 inch diameter, and look good on the car. I can only run these tires inside the stock wheel wells because I have coilovers, and the correct back space. 15x8 w5" b.s, and 16 x 8 w 5" b.s Quote Link to comment Share on other sites More sharing options...
Guest thepenguin99 Posted April 11, 2003 Share Posted April 11, 2003 thx for the help guys. I think im going to try and find the tires locally then hit tire rack again if I have no luck. Quote Link to comment Share on other sites More sharing options...
madmanadam Posted April 12, 2003 Share Posted April 12, 2003 This might help, http://amsoft.ru/tiresize/index.html http://amsoft.ru/tiresize/index.html?ws17=1&ws14=1&ws21=1&tiresize=205/70/14,%20255/45/17&minwidth=&maxwidth=&minratio=&maxratio=&minwheel=&maxwheel=&maxdelta=2 Adam Quote Link to comment Share on other sites More sharing options...
madmanadam Posted April 19, 2003 Share Posted April 19, 2003 Hi, Just got my wheel and tires They are Centerline PinTail 17 x 8 with kumo 245/45/17 rear 235/45 front The tires I had on the car were 14 x 5.5 with 205/70/14 all around. I set the tires side by side and they were the same height. 25.3" Quote Link to comment Share on other sites More sharing options...
