Doug71zt Posted May 9, 2003 Share Posted May 9, 2003 I need some new plugs for my L28 turbo - I'm wondering what everyone is using. I've heard that one heat range colder works well on higher output turbo engines. How about brand? Thanks - Doug Quote Link to comment Share on other sites More sharing options...
J Taylor Posted May 9, 2003 Share Posted May 9, 2003 NGK, all the way. I use a "7" in my z which is one step colder but if you running a mild setup I probably wouldn't bother. JT Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 9, 2003 Share Posted May 9, 2003 I use Bosch dual electrode platinums from a 98 BMW M3. They work well and are easy to index. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 9, 2003 Share Posted May 9, 2003 Ditto on the NGK 7 temperature range. The BMW application sounds interesting too, no monkeying with gap it sounds like. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted May 9, 2003 Share Posted May 9, 2003 NGK 7's for me too. Quote Link to comment Share on other sites More sharing options...
jgkurz Posted May 10, 2003 Share Posted May 10, 2003 I run the NGK BPR6ES-11. Do you guys notice any difference with the "7"'s? Good or Bad? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted May 10, 2003 Share Posted May 10, 2003 I run the NGK BPR6ES-11. Do you guys notice any difference with the "7"'s? Good or Bad? Running 14 psi boost, the 6s will be bleached white. The 7s remain a nice tan color. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 12, 2003 Share Posted May 12, 2003 The M3 plugs I use are the same heat range as an NGK, which is a 7. FWIW the guy that put me on them sold me a set of heat range 2's, which are way to hot. Needless to say, his tuning tips are not listened to anymore. I don't have to gap them, and I don't have trouble firing them with the stock coil, no matter how much boost I have run. Nice clean tan burn too. Quote Link to comment Share on other sites More sharing options...
