What style oil adapter do i need to put a oil cooler on my z
I used a stock 280zx turbo oil cooler adaptor out of an automatic. I had it tapped for 1/2 npt and then ran braided hose to a large B&M oil cooler in between the intercooler and radiator. You would only have to unscrew the oil filter stud from the block to put it on.
ford/chysler kit bolts right up, since L motors use same size filters as ford V8s. works great i run mine to a B and M tranny cooler, with the supplied high pressure line, works great, with the left over line i used it for fuel line, also works great for that too!!!! not sure if im getting the greatest cooling, but its better than no oil cooler right?
I added a dual remote filter kit to my Z, then just continued out the remote filter to a Ford SHO trans cooler, then back to the adapter plate. Ran it all in braided stainless, have about 300 miles on it and all seems good.
Bill
