Guest Anonymous Posted June 6, 2003 Share Posted June 6, 2003 Anybody know anything about Mazda Miata seats and what year seats will fit in a 1978 280Z? Quote Link to comment Share on other sites More sharing options...
innerware Posted June 7, 2003 Share Posted June 7, 2003 I have the same question. I have heard though that most will fit with minor mods. Quote Link to comment Share on other sites More sharing options...
S30Z Bushido Posted June 7, 2003 Share Posted June 7, 2003 i got miata seats, all years will work. replace the mazda rails w/ the nissan rails and use washers as spacers to clear the bottom the the seat from the floor, pretty simple install. Quote Link to comment Share on other sites More sharing options...
Boobala Posted June 9, 2003 Share Posted June 9, 2003 I recently had a pair of Miata seats shipped to me. The pair weighed 74lbs. Quote Link to comment Share on other sites More sharing options...
Boobala Posted June 12, 2003 Share Posted June 12, 2003 Correction: The pair weighed 72lbs. Quote Link to comment Share on other sites More sharing options...
Turbo6inKY Posted October 31, 2003 Share Posted October 31, 2003 i got miata seats, all years will work. replace the mazda rails w/ the nissan rails and use washers as spacers to clear the bottom the the seat from the floor, pretty simple install. I just nabbed a set of Miata seats, and they bolt locations on the bottom of the seats aren't even remotely close to the bolts on the Z's rails. Did you have to drill new holes in the rails? Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted November 1, 2003 Share Posted November 1, 2003 how much do stock 240 seats weigh? either individually or both together? Just curious. I'm considering finding a set of Miata seats also... Quote Link to comment Share on other sites More sharing options...
Garrett76Zt Posted November 1, 2003 Share Posted November 1, 2003 I recently put in a set of z31 seats(86), gutted the electronics and power lombar, etc. THey still weigh a bit more than stock but they are really snug, comfortable and apporopriately read, "TURBO" Quote Link to comment Share on other sites More sharing options...
utvolman99 Posted November 2, 2003 Share Posted November 2, 2003 i got miata seats' date=' all years will work. replace the mazda rails w/ the nissan rails and use washers as spacers to clear the bottom the the seat from the floor, pretty simple install.[/quote'] I just nabbed a set of Miata seats, and they bolt locations on the bottom of the seats aren't even remotely close to the bolts on the Z's rails. Did you have to drill new holes in the rails? Yes, you need to drill new holes in the Z sliders. It's been a while so I am a little foggy on this but I think I kept the original front holes and drilled new rear holes. Also, I am 6'3" tall and didnt want to add any spacers to the seats. If I rememeber right one side bolted right on with no spacers and the other side (the one with the adjuster) I had to use a die grinder to cut some of the alluminum pan from under the seat. Also, the mazda seat is more narrow than the Z seat so you will have to drill new holes in the seat frame in the car. I just kept my existing holes that were near the console and drilled new holes on the door side. I cant really tell that my seat is 1/2" off center from the wheel and it gives me more room with the roll bar. Hope this helps. Quote Link to comment Share on other sites More sharing options...
zguy95135 Posted November 21, 2003 Share Posted November 21, 2003 how much do stock 240 seats weigh? either individually or both together? Just curious. I'm considering finding a set of Miata seats also... all i know is that they are HEAVY. i have taken them out more times then i can count. man im glad they're gone! even the sliders them selves add a good amount of weight to aftermarket seats Quote Link to comment Share on other sites More sharing options...
Guest ZmeFly Posted November 21, 2003 Share Posted November 21, 2003 especially in the later models 98 99 and above, I myself have Z32 seats in my car, fully adjustable (manually of course) but nonetheless very nice and still NISSAN Quote Link to comment Share on other sites More sharing options...
