THUNDERZ Posted June 13, 2003 Share Posted June 13, 2003 What is the best ignition system for the money on a L28. The motor is bored, ported, triple carbs and exhaust system. I think that I should improve the stock set up , but not sure how far to go. Jim Quote Link to comment Share on other sites More sharing options...
fl327 Posted June 13, 2003 Share Posted June 13, 2003 e12-80 zx or maxima ignition module and distributor 84-89 300zx coil ngk wires Quote Link to comment Share on other sites More sharing options...
Mike C Posted June 13, 2003 Share Posted June 13, 2003 Depends, as usual. The conclusion I came to was the Mallory dual point. The reasons: Pluses: $200 cheaper than the Unilite adjustable advance curve No vacuum advance, triples are notorious for not providing enough vac in one runner to fully activate said advance in Nissan distributor. Minuses: BUT, you have to deal with the points. I've done that in my 240's anyhow. Pertronix does make an Ignitor that will fit the dual point, but Crane and Mallor do not. I plan on removing one set of points from my Mallory and using the other to fire my Crane HI6 and MSD Blaster 2 coil. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted June 19, 2003 Share Posted June 19, 2003 I was using a 300ZX coil, but I have been experiencing trouble lately with the car shutting off, so I switched to a MSD Blaster3 coil. So far it seems to work ok. Quote Link to comment Share on other sites More sharing options...
