302 motor weight
i know this has been kicked around but i want some answers.my 77 z is used as a daily driver but also gets used for open track and driver schools at thunderhill,sears point,laguna seca.i have spent years swapping parts to get the car to handle good enough to run against trailered race cars.engine is a 81 zxt.the 302 is simple and cheap-i work as a tech at a ford dealer.i want more power,better weight balance,less parts under the hood.i would bet that a 302 long block is lighter than a turbo l28 with same parts mounted.302 would have aluminum heads.main problem is keeping the car handling the same or improving it.no weight can be added to the front.car is 1350 lbs front 1270 rear.
This is grumpy's engine list from the chevy forum. Surpising what a search will turn up... :D
ENGINE DIMENSIONS
all lengths are in inches, weights are in pounds
C.I.D. WIDTH LENGTH HEIGHT WEIGHT
CHEV V6 200 26 24 27 400 lbs
V8 262,265
283,302
305,307
327,350
400 26W 28L 27H 575lbs
348,409 28 1/2 34 1/2 32 685lbs
396,402
427,454 28 30 1/2 29 685lbs
FORD V8 221,260
289,302
351W 24W 29L 27 1/2H 460lbs
232,292
312 28W 29L 29H 625lbs
302 Boss 24W 29L 29H 500lbs
351C 24 1/2W 29L 28 1/2H 550lbs
332,352
390,406
410,427 27W 32L 29H 625lbs
427 sohc 32W 34L 29H 680lbs
429,460 27W 30L 29H 720lbs
429 Boss 28W 34L 30H 635lbs
MOPAR V8 273,318
340,360 24W 29L 27H 550lbs
361,383
340,413
426,440 29 1/2W 30L 29H 670lbs
331,354
392 29W 31L 31H 765lbs
426 29W 32L 32H 690lbs
BUICK V6 198,225
231 26W 23L 28 1/2H 400lbs
231 Turbo 30W 23L 30H 430lbs
215 Aluminum 26W 28L 27H 320lbs
350 28 1/2W 30 1/2L 28 1/2H 450lbs
401,425
Nailhead 28W 33 1/2L 29H 650lbs
400,430
455 28W 30L 30H 600lbs
CADILLAC V8 472,500 28 30 1/2 28 600lbs
OLDS V6 198,225
V8 215 Aluminum 26W 28L 27H 320lbs
260,330
350,403 26W 28L 27 1/2H 560lbs
303,394 30W 32L 29H 700lbs
400,425
456 26 1/2W 31L 29H 620lbs
PONTIAC V8 215 Aluminum 26 28 27 320lbs
301 25W 32L 30H 475lbs
326,350
389,400
428,455 25 1/2W 32L 30H 640lbs
--HEIGHT IS FROM AIR CLEANER TO PAN--
--LENGTH INCLUDES WATER PUMP--
--WIDTH INCLUDES HEADS, VALVE COVERS,MANIFOLDS--
since you work at a dealership, i bet you can get a good deal on an
r302 block, 4 bolt main alloy 302 teamed up with gt40 heads and the E cam, youll dust fools with that setup and i bet it will handle something fierce, since the motor would weigh very little, and the dist in the front you could shove that thing very far back and probably pick up weight in the rear from the swap!
My personal experience in dealing with the weight of a SBF (289/302) is this. Aluminum heads, aluminum flywheel, cheap but light aluminum water pump, light aluminum manifold w/carb (some aluminum manifolds are quite heavy), and moderate medium length headers ran it just at 400 lbs (actually it totaled to 390 lbs, but I may have not had the distributor and some other small stuff added correctly. It was actually lighter than the same parts-for-parts as the L24 that it was swapped out for.
back in my younger days i could pick up a bare 302 block and carry it.i never could lift a l28 block.plan is for a solid roller lifter ,aluminum head 302 built for 7000 rpm.the hydraulic roller lifters are heavy.so you need big valve springs.not good-you are losing power opening the valves up.
Guest Looking for apt in Alb Ny
hey blue oval.. I love your car. its what i have thought my car to look like when i get to the body. very nice job!!!! I think Ill stick with my turbo for a while till the engine blows. Juan @ JSK
I haven't weighed the engine itself, but I have weighed the entire car and the front to rear bias.
2600 with 16 gallons of gas
1320 on rear
1280 on front
My car has 1989 5.0L with
edelbrock aluminum heads
Cobra Intake
24 lb injectors
73mm MAF
70mm TB
T5 tranny
Battery in back
