bumble zee Posted July 23, 2003 Share Posted July 23, 2003 i have recently just learned that there is a difference between the 75-76 and 77-78 fuel tanks. what is the difference, and what one do i want to use on my 240 turbo swap? Quote Link to comment Share on other sites More sharing options...
Mudge Posted July 23, 2003 Share Posted July 23, 2003 I thought the 77 was the perfect year to own, but dont quote me on that. Bump for ya Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted July 23, 2003 Share Posted July 23, 2003 most people will recommend using the early 280z fuel tank, however I've recently talked to a few people that run their turbos from the stock 240 tank, with some slight modification. Namely, you want the fuel pickup line to come from the bottom of the tank, I dont know the exact details but from what I can gather it's very easy to do. This is how my car is going to be setup. Quote Link to comment Share on other sites More sharing options...
onephatz Posted July 29, 2003 Share Posted July 29, 2003 i recently installed a turbo zx motor into a '72 and all i did was T the return line into the feed line from the tank. the pump just keeps looping the extra fuel and sucks only what extra it needs from the tank. it works amazingly well. I used the stock vent line that were fed into the carbs as the return line. good luck jesse Quote Link to comment Share on other sites More sharing options...
yo2001 Posted July 29, 2003 Share Posted July 29, 2003 If you are going to swap the tank, you'll need the 75-76 tank. 77-78 are different shape and also bigger. If you are going to used the 240 tank, you need the larger return line I was told. Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted July 29, 2003 Share Posted July 29, 2003 a efi tank has a baffle around the fuel pick up to help prevent fuel starvation in turns.my 77 will start missing at 1/4 while on track.the efi tanks a 11 mm out put line and a 8mm return line.with the 11 mm output you could feed a lot of horsepower with the correct pump. Quote Link to comment Share on other sites More sharing options...
