Ign Timing L28 Turbo
I just finished installing an 83 Turbo motor into my 76Z. The entire 83 ECCS system is being used. I just got the motor fired up and the timing is about 18 degrees AFTER TDC (off the scale) at idle! :shock:
I had the oil pump and the dist out. Did I put them in on the wrong gear tooth? Where should the idle timing be and how do I get it there?
Photos and a video-->http://www.hvmp.com/dc
Thanks,
Dave C.
Thanks, I was afraid that I had to drop the pump again....oh well. I appreciate the info. I need to go about 38 degrees advanced from where it is now. That should help my throttle response. :lol:
Dave C.
Nice Dyno Numbers by the way SleeperZ!
Thanks' date=' I was afraid that I had to drop the pump again....oh well. I appreciate the info. I need to go about 38 degrees advanced from where it is now. That should help my throttle response. :lol:
Dave C.
Nice Dyno Numbers by the way SleeperZ![/quote']
:cheers: Thanks.
  • 5 years later...
