Guest szlash280z Posted August 15, 2003 Share Posted August 15, 2003 when you do a turbo swap, make sure that you mount your ECU to the car. I still haven't done mounted mine, but everytime I make a hard left turn, it falls out of it's place and wedges my dang clutch pedal to the floor! I have to stop the car to get it out! I wish the ECU for the Turbo was the exact same size as the NA, I would have mounted it already! Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted August 15, 2003 Share Posted August 15, 2003 Lol! You know that ECUs (same as computers) only do what you tell them to do.. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted August 15, 2003 Share Posted August 15, 2003 Uh, don't the ECU's have to be grounded? That is the case with most of them... Quote Link to comment Share on other sites More sharing options...
Tim240z Posted August 15, 2003 Share Posted August 15, 2003 Uh, don't the ECU's have to be grounded? That is the case with most of them... Sometimes we all need to be grounded in some fashion Quote Link to comment Share on other sites More sharing options...
fl327 Posted August 15, 2003 Share Posted August 15, 2003 Mounting ecu solidly is good idea. If it flails around excessively, wire connections and pins can bend. This causing bad running and premature failure. My ecu runs great, ecu used to be on floor, now moved to driver side kick panel. No running problems not grounding the CECU, but thats just me. Quote Link to comment Share on other sites More sharing options...
Guest szlash280z Posted August 17, 2003 Share Posted August 17, 2003 mine is not grounded and it works fine. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted August 17, 2003 Share Posted August 17, 2003 FYI, Z31 ECU fits just right on 280Z's original ECU spot. I thought it was neat Quote Link to comment Share on other sites More sharing options...
