Guest Willieboy240z Posted August 18, 2003 Share Posted August 18, 2003 Inspired by posts I read here, I have modified my fuel door to a brushed aluminum aftermarket part designed for a Mazda Miata. I got the mechanism from a junkyard and ordered the alum door off the web. Unlike the motorcycle tank lid conversion I abandoned earlier, this mod does not require any changes to the stock gas cap or pipe. And your gas supply is secured without needing a key. The remote control switch was mounted beneath the console. I had originally thought it would be mounted in the more traditional location to on the floorboard/rocker panel area, but later decided just to put it here so I didn't have to find another cable. Very smooth operation. Quote Link to comment Share on other sites More sharing options...
Dayz Posted August 18, 2003 Share Posted August 18, 2003 Awesome, just perfect and I want to do the same thing when it is going to be the time !!1 can you post the parts and a pic of the inside. Or the process!! Nice work Dayz Quote Link to comment Share on other sites More sharing options...
jeromio Posted August 18, 2003 Share Posted August 18, 2003 That does look mighty nice. Is the old hole welded up? Filled with lead, bondo? Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted August 18, 2003 Share Posted August 18, 2003 Nice work . I was wondering also if you welded up the old hole first. I am going to try using a bullitt mustang fuel door when it's time for body work. No cable needed. Quote Link to comment Share on other sites More sharing options...
timh Posted August 18, 2003 Share Posted August 18, 2003 I bet that's a new quarter panel, and didn't have a cutout? Quote Link to comment Share on other sites More sharing options...
Guest Willieboy240z Posted August 18, 2003 Share Posted August 18, 2003 A fair amount of cutting (including from the inside) was required. Gaps filled with sheet metal with some bondo here and there. Also, the car has shaved doorhandles, locks, decklid latch lock deleted side markers, badging, pillar vents combined fenders/headlight buckets Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted August 18, 2003 Share Posted August 18, 2003 A fair amount of cutting (including from the inside) was required. Gaps filled with sheet metal with some bondo here and there. Also' date=' the car has shaved doorhandles, locks, decklid latch lock deleted side markers, badging, pillar vents combined fenders/headlight buckets[/quote'] Man that sounds sweet guy... why don't you bless us with some pics of those mods in your personal pic gallery... j. Quote Link to comment Share on other sites More sharing options...
j260z Posted August 19, 2003 Share Posted August 19, 2003 this is the kind of work and attention to detail that keeps me coming to this site every day. awesome work!! of course, that being said, now you must divulge your secrets. where did you order that door from and what mechanism are you using? Quote Link to comment Share on other sites More sharing options...
DavyZ Posted August 19, 2003 Share Posted August 19, 2003 Extremely nice work, not to mention functional too By chance, did the door have a slight curve in it to match the quarter panel curve of the Z? Your work looks 'factory' only using custom parts Me like. Davy Quote Link to comment Share on other sites More sharing options...
t-tom Posted August 19, 2003 Share Posted August 19, 2003 I love that color! Makes me not want to paint my fairlady yellow. Quote Link to comment Share on other sites More sharing options...
Guest Willieboy240z Posted August 19, 2003 Share Posted August 19, 2003 The door came from a website that featured Mazda Miata parts. I can't remember the name -- it was about a year ago. The mechanism came off a run-of-the-mill Miata I found in a junkyard. Here's a source for the fuel door. http://www.miatamania.com/Shop/ViewProducts.aspx?PlateIndexID=33157 The door is pretty much flat. The color of the car is BASF yellow tint, pretty much straight out of the can. Quote Link to comment Share on other sites More sharing options...
niceguy678us Posted August 19, 2003 Share Posted August 19, 2003 I just went to the J/Y and looked at a recked miata. Did you cut out a patch of the sheet metal from the miata and graft it into the datsun quarter panel? I was wondering if I needed to hack out this chunk out of the Miata so I could have the latch mechanism ( I know you just undo that 14mm nut and the part will slide out) I mean the female part of it located on the door. Quote Link to comment Share on other sites More sharing options...
Guest Willieboy240z Posted August 19, 2003 Share Posted August 19, 2003 No, I didn't. But it sounds like it might be worth trying.... Quote Link to comment Share on other sites More sharing options...
niceguy678us Posted August 19, 2003 Share Posted August 19, 2003 sweet, I PM'd you thinking you might not see this before you left the forum, just wanted to make sure as I am going back to the J/Y again to pick up these parts. Thanks again for the miata parts link!!! Quote Link to comment Share on other sites More sharing options...
