jeffp Posted September 5, 2003 Share Posted September 5, 2003 I posted this on Zcar last night, take a look and tell me what you think. Hi everyone, I just got these part pieced together today. I think they turned out good. What do you think? I am going to have them tig welded and then power coated texture black. The link is http://www.angelfire.com/extreme/280zxt/page2.html Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted September 5, 2003 Share Posted September 5, 2003 jeffp said: What do you think? Me thinks you need more bandwidth Post a pic in your album Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted September 5, 2003 Share Posted September 5, 2003 Quote Quote What do you think? Me thinks you need more bandwidth Post a pic in your album Ditto, I tried last night and today, you have run out of BW. The price of being popular, Jeff! Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted September 6, 2003 Share Posted September 6, 2003 I got to see it this morning. Looks like some good plumbing. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted September 6, 2003 Share Posted September 6, 2003 So, when is this monster going to turn a wheel in anger? Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted September 6, 2003 Share Posted September 6, 2003 Scottie-GNZ said: So, when is this monster going to turn a wheel in anger? Good question! Quote Link to comment Share on other sites More sharing options...
jeffp Posted September 7, 2003 Author Share Posted September 7, 2003 The car is coming along nicely and is very close to put back on the ground. I have decided to take a little more time and complete the suspension package total upgrade. I ripped one of the sway bar straps on the left side. I am going to machine a bracket for that out of aluminum. I had to buy special order bolts in an allen head, but the 1.25 pitch thread is special order. One of the SIGNIFICANT things I am working on is the lower control arm bushings. I installed the derlin and aluminum insert adjustable bushings, but when I made the caster adjustable, and pulled the front wheels 6-6.5 drgrees forward, the lower control arm bushings went bad, to much force trying to pull the wheels that far forward. So the Derlin bushing install is out. I am installing 3.4" sphearical ball rod ends on the lower control arm. Good to go, but now I am going to have to get camber plates, as it is to difficult to make the lower control arm adjustable, and that will make a weaker part being adjustable. I contacted a company off my web page, dont remember who, but they say they have a generic camber plate that will fit my car. I will have to drill the holes to mount the plate to the shock tower, and maybe turn a shim for the shock to to fit right. The big thing is that I may have to take to the car with a hole saw to make the center hole bigger for the camber plate adjusters, and I am not all the keen on that aspect of the install. I am just going to have to put my eyeballs on the adjuster and see if I really fit on my car and my stock schock and spring setup. Most people go coil overs with that application, but I dont want to go that way with the car, maybe the back as a fun project someday. So that is what I have to finish up in the fabrication department, and the rest of the stuff is just bolt on for the most part. WHO KNOWS LOL I got to get it right or it will never hold a front end alignment well. Quote Link to comment Share on other sites More sharing options...
