240ZinTN Posted October 24, 2003 Share Posted October 24, 2003 I have search for an answer but can't seem to find what I need. I am trying to set up an L28ET with a Z31 ECU. Do I have to use a turbo ECU and wire harness? I have 280ZXT harness and lots of Z31 n/a ECUs, are they compatable? I know I will have to use a Z31 MAS instead of an AFM. I can get a Z31 n/a harness if this would be easier. The Z31 turbo ECU and harnesses are a little harder to find and since I have all these other parts I am hoping I can use to save $ for SVO 370cc injectors. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted October 24, 2003 Share Posted October 24, 2003 Keep searching. You are not asking anything new - we've recently discussed differences in Z31 ECUs, harnesses and wiring. Here are two to start on. http://www.hybridz.org/phpBB2/viewtopic.php?t=25962 http://www.hybridz.org/phpBB2/viewtopic.php?t=26898 Quote Link to comment Share on other sites More sharing options...
240ZinTN Posted October 25, 2003 Author Share Posted October 25, 2003 I have been searching for answers to my questions and have been following the posts you recommended but they still do not provide the answers I am looking for (I even re-read them again before posting this just to be sure I didn't miss something). If someone could simply give me a yes or no on... Will the z31 na ECU and harness work just as well as the turbo versions? I would be extremely grateful. Once I have that to start with I will figure out the rest. Thanks Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted October 25, 2003 Share Posted October 25, 2003 I agree... those posts definately do not contain the answers to the specific questions he is asking. I only pitch in because I would definately like more info on a Z31 setup too, as far as, exactly what parts from which car will end up in the final setup. And a final answer on just how hard it would be to pull it off. Quote Link to comment Share on other sites More sharing options...
BRAD D Posted October 25, 2003 Share Posted October 25, 2003 i know Bernardd (a hybridZ member form my aera) is running this set up. With some geat results, but I think he is still ironing out bugs. Quote Link to comment Share on other sites More sharing options...
240ZinTN Posted October 25, 2003 Author Share Posted October 25, 2003 I did find some more info in the second series of posts Sleeper referred to. Just posted today. I ran the turbo ECU from 87. It 's better for me because it pulls timing under boost. I don't think the N/A ECU will do that. ( I hope that quote works) from what I can tell so far it looks like a z31 N/A set up will work but not as well. yo2001 doesn't sound to sure and it doesn't look like he actually tried a N/A ECU.. Can anyone clarify this before I put in several hours following and cutting wires. Quote Link to comment Share on other sites More sharing options...
fl327 Posted October 25, 2003 Share Posted October 25, 2003 when I looked in my manual last, when it shows z31 harness pinout, na and turbo are shown together, while 70-83 turbo and NA are completely different. I believe they are the same for the most part, just from looking at the book, but cant be sure. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted October 25, 2003 Share Posted October 25, 2003 I think everyone is wandering about how to hack up the harness. I can't tell you because I got mine pre hacked But all you need is Z31 schematic, ZXT schematic, colored pencils, and alot of time stearing at lines. Once the harness is really, only thing you do is pretty much hook the sensors, grounds, and harnesses. Here is what you need to get Z31 ECU run 12V to MAF from an ignition realy 12V for self cleaning grounds to MAF 0-5v signals to ECU from MAF TPS (no mod there) CAS (no mod there) 12V constant from a battery to ignition relay ignition 12V from the ignition switch ignitor Dizzy CAS swap 6 injector signals from ECU to injectors I think that's all I got hooked up. Quote Link to comment Share on other sites More sharing options...
fl327 Posted October 25, 2003 Share Posted October 25, 2003 I think everyone is wandering about how to hack up the harness. I can't tell you because I got mine pre hacked But all you need is Z31 schematic' date=' ZXT schematic, colored pencils, and alot of time stearing at lines. Once the harness is really, only thing you do is pretty much hook the sensors, grounds, and harnesses. Here is what you need to get Z31 ECU run 12V to MAF from an ignition realy 12V for self cleaning grounds to MAF 0-5v signals to ECU from MAF TPS (no mod there) CAS (no mod there) 12V constant from a battery to ignition relay ignition 12V from the ignition switch ignitor Dizzy CAS swap 6 injector signals from ECU to injectors I think that's all I got hooked up.[/quote'] yup .its really that easy. also, notice that at least three of the steps are to the one MAF plug. its not very difficult at all, but I could see it getting frustrating though if you are new to efi. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted October 25, 2003 Share Posted October 25, 2003 I think everyone is wandering about how to hack up the harness. I can't tell you because I got mine pre hacked But all you need is Z31 schematic' date=' ZXT schematic, colored pencils, and alot of time stearing at lines. Once the harness is really, only thing you do is pretty much hook the sensors, grounds, and harnesses. Here is what you need to get Z31 ECU run 12V to MAF from an ignition realy 12V for self cleaning grounds to MAF 0-5v signals to ECU from MAF TPS (no mod there) CAS (no mod there) 12V constant from a battery to ignition relay ignition 12V from the ignition switch ignitor Dizzy CAS swap 6 injector signals from ECU to injectors I think that's all I got hooked up.[/quote'] yup .its really that easy. also, notice that at least three of the steps are to the one MAF plug. its not very difficult at all, but I could see it getting frustrating though if you are new to efi. And if you are new to EFI, don't jump right into this swap. Install the factory system and get that going. Troubleshoot it and otherwise get to know EFI. Quote Link to comment Share on other sites More sharing options...
fl327 Posted October 26, 2003 Share Posted October 26, 2003 I think everyone is wandering about how to hack up the harness. I can't tell you because I got mine pre hacked But all you need is Z31 schematic' date=' ZXT schematic, colored pencils, and alot of time stearing at lines. Once the harness is really, only thing you do is pretty much hook the sensors, grounds, and harnesses. Here is what you need to get Z31 ECU run 12V to MAF from an ignition realy 12V for self cleaning grounds to MAF 0-5v signals to ECU from MAF TPS (no mod there) CAS (no mod there) 12V constant from a battery to ignition relay ignition 12V from the ignition switch ignitor Dizzy CAS swap 6 injector signals from ECU to injectors I think that's all I got hooked up.[/quote'] yup .its really that easy. also, notice that at least three of the steps are to the one MAF plug. its not very difficult at all, but I could see it getting frustrating though if you are new to efi. And if you are new to EFI, don't jump right into this swap. Install the factory system and get that going. Troubleshoot it and otherwise get to know EFI. what he said 8) Quote Link to comment Share on other sites More sharing options...
240ZinTN Posted October 27, 2003 Author Share Posted October 27, 2003 Thanks, that answers many questions, some I didn't even think to ask. Quote Link to comment Share on other sites More sharing options...
