Guest twinturbo240z Posted November 3, 2003 Share Posted November 3, 2003 Hi, I have a 72 240z that I am planning on prepping for some autox, road course, etc. The car is pretty much stock. My future plans for the car are: coilovers, urethane bushings, disk brakes, and Lt1 T56. My question for all of you who have done this already is what order would you do these things if you were going the same route as I am. I have already done a lot of searching through the for forums but couldn't find info on this particular topic. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
260DET Posted November 3, 2003 Share Posted November 3, 2003 For brake and suspension info, did you search the Brakes, Wheels, Suspension & Chassis section? There has been a lot of discussion on what you are interested in recently. Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted November 3, 2003 Share Posted November 3, 2003 Ditto what 260DET said. But, since you are reading this, I would do these in order: 1. Brakes Why? Because this is the most important aspect of a performace car. All the horse power in the world isn't going to save you if you can't stop. 2. Urethane bushings Tightens up the suspension. 3. Coilovers Make sure that coilovers are right for you, before you invest in them. 4. LT1 This is the last thing you should think about. Don't get me wrong, keep your goals in mind, but don't upgrade the engine before you look at the saftey of yourself and others on the road. Lastly, do a search for each of the topics listed above. 1-3 can be found in the "Brakes, Wheels, Suspension, and Chassis" forum. While your engine questions can be answered by searching the "Chevy V8Z Tech Board" !M! Quote Link to comment Share on other sites More sharing options...
JKDGabe Posted November 3, 2003 Share Posted November 3, 2003 They're right about the searching of course... I've learned a tremendous amount about Z's just by surfing the old posts. The first thing I would do is the body. Get rid of all the rust, then frame stiffeners, then brakes/suspension. Quote Link to comment Share on other sites More sharing options...
EvilRufusKay Posted November 4, 2003 Share Posted November 4, 2003 Time for a different opinion: 1 - bushings - loose sterring causes wrecks. 2 - brakes - I did the conversion and was not as impressed as I thought I would be with the difference. 3 - Coil overs - finish up the suspension before the big project. 4 - LT1 / T56 - Most work and cash. things might happen before you get to this and if you needed to dump your car it wouldn't hurt as much!!! Quote Link to comment Share on other sites More sharing options...
Guest twinturbo240z Posted November 4, 2003 Share Posted November 4, 2003 thank you all for the advice. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted November 6, 2003 Share Posted November 6, 2003 suspension and bushings first... then exhaust and intake then brakes then add the engine. (gotta have the right stance first) then the sound Quote Link to comment Share on other sites More sharing options...
