hjc74260Z Posted November 6, 2003 Share Posted November 6, 2003 I plan to use a 1970 LT-1 with a Muncie 4 speed for my '74 260Z. I have everything but the throwout bearing. Is there an alternative to the McLeod hydraulic throwout bearing? They are awfully expensive on the McLeod web site. Those of you using a McLeod bearing - Where did you buy it and what did it cost? I know, I know - I should be using a 5-speed but the car will only be driven once or twice a month and then primarily on back roads. I got very close to buying a TKO but figured I could finish the car for the $2000 I would have spent on the tranny and had a good Muncie laying on the shelf. I did several searches on the site and came up empty. Quote Link to comment Share on other sites More sharing options...
Guest Thurem Posted November 6, 2003 Share Posted November 6, 2003 I think Howe makes one, also try a search on summit I think they have some. 150 $ range. Quote Link to comment Share on other sites More sharing options...
V8ZRACER260Z Posted November 6, 2003 Share Posted November 6, 2003 I'll check a catalog I have at home for a throwout bearing with an internal mechanical stop, line & master cylinder. I belive the entire set up was less than $300.00. I'll post it tomorrow. Rick Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted November 7, 2003 Share Posted November 7, 2003 I got mine from PAW http://www.pawinc.com/ . Their web site sucks and the McLeod setup still costs $300, but it worked well for the time I had the car, except for the swivel fittings, which can be fixed with copper washers. Quote Link to comment Share on other sites More sharing options...
Mike C Posted November 7, 2003 Share Posted November 7, 2003 You can buy a Lakewood scattershield (or McLeod) that uses the Camaro T5 slave setup. It is drilled for both conventional Muncie and the rotated T5 patterns. Then you can just use the same setup as detailed in the JTR manual. This will be easier to solve hydraulic issues for sure, about the same price, but you get the added security of an explosion proof bellhousing. Another alternative is the 84-88 Corvette bellhousing. I think the hydraulic setup is easier to adapt than the Camaro one since you don't have to deal with the plastic line, but still not explosion proof. Might be worth a call to see if any of the vendors have a part# for a scattershield in an 84-88 'vette. Quote Link to comment Share on other sites More sharing options...
Trevor Posted November 7, 2003 Share Posted November 7, 2003 There is a McLeod unit on eBay: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2441551913&category=33733 Quote Link to comment Share on other sites More sharing options...
hjc74260Z Posted November 8, 2003 Author Share Posted November 8, 2003 Thanks for your responses. I bought a Howe model 82870 from Summit for $149.00. The only way to find a listing for this part at Summit is to do a google search. You can't get to the listing by going through their menus. I already had the Howe 7/8" cylinder so I now have every part needed to complete the swap except the drive shaft. I'll wait until the new engine and transmission are in before getting that made. Quote Link to comment Share on other sites More sharing options...
fl327 Posted November 8, 2003 Share Posted November 8, 2003 if you can find the infamous scarab bellhousing, you can use a stock datsun slave cylinder. i ran a m21 in my old v8z, best tranny ever made Afaik, nothing i could do would get it to stop working, nothing. blew my first engine before that trans, blew my first mustache bar before it, blew halfshaft, mounts. only two constants---r200 didnt go and the m21 wouldnt stop rockin. tilton master cylinder and a stock datsun slave, modded to be adjustable and used corvette clutch fork to secure adjustments, worked well. Quote Link to comment Share on other sites More sharing options...
Trevor Posted December 1, 2003 Share Posted December 1, 2003 Here are a couple that went for about $50 ebay..... http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2443639013&category=33730&rd=1 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2444389531&category=33730&rd=1 Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted December 3, 2003 Share Posted December 3, 2003 Here's my $.02 worth. If you have room for a slave cylinder, go that route. Its sure a lot easier to work on if you have any problems as opposed to pulling the tranny all the time, which you'd need to do if you have a hydraulic throwout bearing. If I were to use a hydraulic throwout bearing, I'd get the best available ($150 ain't so cheap if you're always pulling your tranny to fix something). Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
