R230 Driveshaft U-Joint/Flange part numbers
Tim240z
Opened a new topic to make searching easier later on.
Just picked up my driveshaft for the T56 to R230. Here are the part numbers for the Tube flange and Universal joint (serviceable) at the R230 Diff. side:
1310 U-Joint: NEUJ 1 0153
1310 Q-45 Conversion Flange: FLNG 3102 69
Hope this helps folks!
Tim
BTW...My driveshaft (using the stock Z28 shaft, shortening, welding flange, both new universals and balancing) cost; $200.14 incl. tax
  • 2 years later...
i just got mine done, looks just like that but my infinity flange is round and matches the diff perfectly, yours seems to be different
Now with it mounted, i have about 1/2" play on the input yoke in the tranny, is this enough? Its give or take a bit because i still have to ge the perfect angle on the diff, and that changes that play slightly, right now my diff needs to come down a tiny bit and angle more up, it points more straight, and the tranny points slightly down, i may just raise the tranny up as well, nothing that a few washers wont fix
i need something to measure the angles, what are you guys using????
