I need MORE 4L80E info for my swap
grumpyvette
ok all you transmission guys, IM also VERY interested in the answers because I purchased a 4L80E to install in my 1985 corvette when I do the swap to the big block engine , because theres no 700r4 thats going to handle the torque numbers that engine will produce, so any info will be greatly appreciated, on how to find cheap ECU/TRANS controllers OR how to modify the 4L80E trans to full manual control. hopefully theres some knowledgeable trans guys on THIS SITE that can help!!?? converters available ? lock up/non-lock-up? performance shift kits? ETC. IM SURE MOST GUYS CAN USE GOOD INFO! heres all the links Ive found......... NO! NOT ALL THOSE QUESTIONS ARE FULLY ANSWERED IN THE LINKS
does anyone have the part number for that manual converion KIT,? or other usefull info?, instructions on the conversion? programing and installation info on the electronic controllers?, part numbers and prices? other options?
does anyone know where a diagram for the connections can be found?
differances between the differant year 4L80E transmissions?
how do the 4L80E trans differ from year to year?
what are the part numbers for the TRANS CONTROLLERS
WHAT STALL SPEED CONVERTERS ARE AVAILABLE and with lock-up?
which are the best built?
what cross members fit?
what drive shaft yoke? part #?
HERES SOME INFO ON THE 4L80E
http://www.atg-autotrans.com/4l80hous.htm
http://www.transmissioncenter.net/4L80E.htm
http://www.transtec.com/specific_trans/4l80e.htm
http://store.yahoo.com/hardparts/4l80e.html
http://www.drivetrain.com/4l80e.html
http://www.fbperformance.com/transmissions/gm4l80e.html
http://www.sallee-chevrolet.com/Transmission_Control_Modules/4L60E_4L80E.html
http://www.compushift.com/
GM PART # 24200161 (wire harness)
http://www.tciauto.com/tech_info/trans_dims_tables.htm#4L80E
http://www.gm.com/automotive/gmpowertrain/transmissions/hydra/apps/4l80.htm
this might help
PLEASE HELP OUT ,ANY USEFULL INFO IS WARMLY ,and GREATFULLY RECIEVED
THIS IS INTERESTING
http://www.kdsperformance.com/tranhigpersh5.html
The ultimate high performance shift kit!!
Includes detailed instructional video.
Engineered for the 'perfect shift' - firm muscle car shifts.
FULL manual shifting.
Perfect for heavy duty/towing applications.
Stops direct clutch burnup.
Prevents hi-pressure damage.
Holds shifts and downshifts to any RPM.
Contains detailed instruction booklet.
Can be installed with transmission in vehicle.
Requires no specialized tools.
100% Made In USA!
Engineered/Designed by Gil Younger - the father of the shift kit.
TR10101 $179.95
Grumpy,
Bowtie overdrives here in California has a standalone module which works in conjunction with a cable (TV) to runt he 4L80E as a stand alone. It is programmable.
http://www.bowtieoverdrives.com/
They have some very nice products and great service. Here is their number:
760/947-5240
Tim
I second what Tim said. Bowtie Overdrives has helped me with my 700r4 immensely. They are very knowledgeable about GM overdrives and have quality products.
Also, if you need a driveshaft, my donor vehicle had a 4L80E trans and I still have the aluminum driveshaft with yoke. You can have it for cost of shipping.
Why not run a full race 200R4? THey take 1400# ft in monster turbo GN's. A completely built trans should run about $2000 or about the same as just the 4L80 trans WITHOUT the $1000 controller needed to run it. I agree with you completely on the 4L60E/700R4. And the gear ratios of the 200 are almost the same as the 4L80. Little more first gear and little more OD both I believe.
Mike C
I got a good deal on a NEW 4L80E still in the factory shipping container, direct from chevy,I fully intend to make it full manual control also, the main reason I picked the 4L80E was that its an overdrive trans AND I know two corvettes that DYNOed over 1000 hp(not a mis-print yeah,1000 rear wheel hp and over 1000 ft lbs of tq useing that trans with no problems)
yeah twin turbo intercooled big block chevy engines
now if it handles that the 650-750hp big block Im planing should be fine
look, at what the upgraded version sells for,
they told me I can upgrade the stock trans to those specs and it will still cost less with what I payed for the stock trans plus with the upgrade than what they ask for the new trans
spdsk8r
" if you need a driveshaft, my donor vehicle had a 4L80E trans and I still have the aluminum driveshaft with yoke. You can have it for cost of shipping."
thank you! please send me shipping weight/cost so I can send you the money for the driveshaft, I can use it!
yes it appears to be just about correct, keep in mind I will be shorting it so I CAN USE IT IN MY BBC ENGINE SWAP IN MY CORVETTTE but I will also be useing it to transfer 600-700hp so that 4" dia. is likely to be usefull
THANKS AGAIN,.. ITS NICE TO HAVE FELLOW HOTRODDERS HELP EACH OTHER OUT AND ITS REALLY APPRECIATED!!!!!
sure ID be glad too! AND I WILL AS SOON AS ITS COMPLETE, but since moneys tight and im still unable to stand as Im recovering from ankle surgery it will be awhile I sorry to say, trust me I want to complete the project badly, but reality keeps getting in the way for me just like it does for some of you gentelmen :D
