LS1240Z Posted December 8, 2003 Share Posted December 8, 2003 I have a 71 240 that I'm swapping the rear-end out of.I have a 93 300Z twin turbo diff with the complete drive line and both cv shafts.The diff is bigger then the old one and the mounts on the rear are a little wider.I know I need to drill the holes on the mustache bar but how do I line up the diff perfectly with the driveline and tranny.Does it have to be perfectly in line?I'm not sure how to line it up on the height wise either.I am still lookin for a drive line shop in the local bay area that can shorten my CV shafts and put a flange on the end of the cv shaft that bolts to the other flange on the stub-axel.IM me if you know of a shop please.My cousin has the same set up with the 300Z diff swap but the owner of Concord Driveline who made them had passed away.His son runs the shop now and he says that he isn't able to do it.I had borrowed one of the shafts from him so I'm able to show them what needs to be done.I called like 3 shops and got denied on all of them so far.I know lots of guys have done this so it cant be impossible.Any advise on this would be helpful.Thanks Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted December 9, 2003 Share Posted December 9, 2003 I would go to a machine shop as opposed to a driveline shop. The adaptors will probably require machining operations (milling) that are probably beyond what most driveline shops are capable of. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
jonzer12 Posted December 9, 2003 Share Posted December 9, 2003 I agree any comptenent machinist should be able to make it for you especially if you can show them an example. What bout modern motorsports, are their adapters suitable for your diff, do you have a r200 or an r230? Quote Link to comment Share on other sites More sharing options...
LS1240Z Posted December 11, 2003 Author Share Posted December 11, 2003 I'm not sure if it's a r200 or r230?I know it's out of a 93 300z twin twin turbo.I have good news though.I went back to Driveline of Concord and showed them the one I borrowed from my cousin and it was a little easier for them to understand what I was talkin about when I showed them my cousins CV shaft.I just got into 240Z's so I'm still learning about the different parts that I'm able to use.I was told that rear end is a little harder to blow up then the older ones so I bought it.I have about 350 to 375 HP to the rear wheels from a 01 LS1 and plan on putting out about 500HP real soon so I just didnt want to keep blowing up rear ends.Thanks for the help though. Quote Link to comment Share on other sites More sharing options...
260DET Posted December 15, 2003 Share Posted December 15, 2003 If it is a R200 it should bolt in using the front mount and the rear mount bar from a later model fitted with a R200. You will need the heavier R200 bar, the R180 bar is not strong enough for your power. Same with the 300ZX CV joints, get them modified to fit. Then you rear end should be pretty well bulletproof. 8) Quote Link to comment Share on other sites More sharing options...
mas28O Posted December 15, 2003 Share Posted December 15, 2003 Is this the LS1 swap that you bought a few months ago? I tke it Darius is your Cousin. Quote Link to comment Share on other sites More sharing options...
LS1240Z Posted December 16, 2003 Author Share Posted December 16, 2003 Yup,you guessed right.Darius is my cousin. I was wondering if it's common for the mustach bar to break?I plan on drilling 2 more holes in it for the new diff and it already has 2 holes in it from the stock diff so I wasnt sure if those holes weakens it or not,thanks Quote Link to comment Share on other sites More sharing options...
LS1240Z Posted December 16, 2003 Author Share Posted December 16, 2003 Thanks for the info 260DET Quote Link to comment Share on other sites More sharing options...
