Finally some pics, and an update...
Got both strut assemblies and torqed on this weekend. Everything looks great and went together fairly easy. (I put the new bushings on the driver side control arm on backwards at first, took me a while to realize it, but once corrected, everything went smooooth.) Got the bolts torqed and all should be well
I also got the driver side floors and frame rail welded in and primered, will try to post fair pics tommorow. So now it is on to the rear suspension, any helpful hints before I start into the rear?
Here are some pics of the sub frame connectors, will try to post some of the suspension soon.
I think that the wire feed WITH the gas set up really helps out ALOT! I know because when ever it was just the wire, i may have forgotten to turn on the gas a couple of times, it was very sparky and throwing junk allover and just not as clean as with the gas. It is the way to go!
