Guest 2002sentraSER Posted December 10, 2003 Share Posted December 10, 2003 i am going to have imsa rear flairs and i wanna know what the biggest tire/ rim combo i can do with a cv conversion b4 i am rubbing the wheel wells offset and size also if there is a site to find adapters for the datsun lug pattern to the chevy or ford lug pattern please let me know Quote Link to comment Share on other sites More sharing options...
fl327 Posted December 10, 2003 Share Posted December 10, 2003 any size you can afford, but they do get cheaper if you do a five stud conversion, but then the five stud costs a nice sum though, but then youre already doing cv so doesnt matter as much. ive seen 300 series tires on a number of imsa flared z cars. chevy lug pattern needs a five stud conversion plus an adapter to the larger chevy 5x4.75 pattern, not enough meat on stock hub to go that big. typical 5x4.5 is always available and its the basic 5 stud pattern for most wheels. what i would do is flare the car first, and take some measurements, odds are with that much room a 300 series tire of any diameter rim you can dream of will fit, i think your biggest issue will be getting one big enough to fit. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted December 10, 2003 Share Posted December 10, 2003 What's the biggest wheel and offset I can place on stock suspension? Can I run 15x8 with -12 offset all the way around without rubbing anywhere? or Can I run 16x8 with +10 offset in the front and 16x8.5 in the rear with a -6 offset safely without rubbing? Quote Link to comment Share on other sites More sharing options...
johnc Posted December 10, 2003 Share Posted December 10, 2003 search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search search! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 10, 2003 Share Posted December 10, 2003 edit Quote Link to comment Share on other sites More sharing options...
Mikelly Posted December 10, 2003 Share Posted December 10, 2003 This topic has been beat into the ground... Do your research... I found the answer to both these questions in no time at all... I just used some patience and READ the information the search engine came back with. Further, making smart comments won't aid in your quest for help... Reading is fundamental... I suggest you employee those skills learned in grade school. Mike Administrator Quote Link to comment Share on other sites More sharing options...
