engine and gearbox position in 240z chassis
Hi all
I race a fairly modified 240z in Australia. The engine/gearbox (L28) are still in the std position and I was wondering if anyone has had any experiance with moving the engine/gearbox back and down a bit to better balance the car.
any info would be greatly appreciated
Ashley
Ashley,
I don’t know how much would be gained. (frt / rear weight bias)
At best (without major mods) you could only move engine back maybe 3â€.
That would move trany / shifter back the same ???
As far as lowering the engine / trany, ground clearance issues ???
Not to say it can’t be done.
I would think that time / money would be better spent in supension tuning to get your car handling and setup where you want it.
And welcome!
I moved mine back exactly 2". The stock hood latch stuff will probably be in the way, I have pins so I don't know. You also can't lower it any more as the oil pump will now sit over the front cross member. I made a new rear trans mount and made 2 motor mount spacers out of 1/4" plate to move the front back, also had to have the D shaft shortend.
