BillZ260 Posted February 4, 2004 Share Posted February 4, 2004 Pulled my tail lights apart last night to get them cleaned up. Exhaust fumes had blackend the driver side pretty good on the inside. So everything is going fine untill my last lens and the thing cracks! ( We need a homer DOH emoticon here) It is the upper Driverside lens, 280 style. Does anyone have the left assembly, or even better, the seperate lenses that they are not going to use? Let me know? If all fails, I will have a cracked lens untill I come up with my 'custom' set up after the car is running. Has anyone pollished their lenses out? The datsun restore book said something about buffing the lens faces with a compound and I was wondering how will this works. Thanks! Quote Link to comment Share on other sites More sharing options...
Phantom Posted February 4, 2004 Share Posted February 4, 2004 If you can't find one in OKC talk to Jerry at All Z Car Specialist in Fort Worth (817) 483-0383. He can pull one off a car in his yard - or you can come down and go on a "shopping spree" for parts in his yard. Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted February 4, 2004 Author Share Posted February 4, 2004 thanks phantom! Quote Link to comment Share on other sites More sharing options...
Vintage-TechZ Posted February 5, 2004 Share Posted February 5, 2004 Bill,If you want the absolute best shine on the tail lens or front signal for that matter, start by removing the assembly carefully,it helps if the unit is very warm to pull it apart. Then start sanding the outside face with a DA or by hand using 240# then 320# and so forth till you are at 1500 #.It goes faster then it sounds.If done by hand ,use a firm hand block. The way I've done it for 25 years is to sand the raised letters completely down and then use automotive paint compound or better yet,3M's Finese-it polish.You should have that on the shelf already if your paint looks worth a darn. Anyway, polish to perfection,I use a Buffer set at low RPM, the buffer on auto-lock between my knee's upside down,and hold the lens in my hands,having already applied the polish on the lens before lowering to buff pad .You'll get the hang of it ! If your careful and pay attension ,they'll better than new ...Guaranteed ! Let me know what ya' think,and good luck .........Vince Quote Link to comment Share on other sites More sharing options...
denny411 Posted February 5, 2004 Share Posted February 5, 2004 I`ve got some spares. sent you a PM. Quote Link to comment Share on other sites More sharing options...
steve72z Posted December 2, 2005 Share Posted December 2, 2005 Meguiars sells a product called Mirror Glaze #17 Proffessional Plastic cleaner. Although Vintage-TechZ's method will give you a superior shine this product works very well for general polishing of almost any plastic. I use it often with great results. Quote Link to comment Share on other sites More sharing options...
240hoke Posted December 2, 2005 Share Posted December 2, 2005 I made a post about this a while back. I used a 3M marine clear plastic restorer. Worked great. Here is the post, got pictures and what not: http://forums.hybridz.org/showthread.php?t=104585 Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted December 2, 2005 Share Posted December 2, 2005 same question, are you making these or are these the same available at klearz.com Quote Link to comment Share on other sites More sharing options...
DavyZ Posted December 2, 2005 Share Posted December 2, 2005 I made a post about this a while back. 240hoke is correct, this thread is over 1 year old. Troy, there is a vendor's forum on thissite for businesses to sell their products. Bringing up a very old thread like this for the purpose of a sale is in bad taste. You are free to answer technical questions, etc, as does Ross Corrigan of MML or Mike Knell of JTR, but please stick to the vendor's forum otherwise. Thank you. Davy Quote Link to comment Share on other sites More sharing options...
