auxilary Posted February 10, 2004 Share Posted February 10, 2004 I need a 255lph or so external fuel pump for the rotary. It will operate at 42-43 psi for the injection, and will be supplying fuel to 2 x 550cc injectors, and 2 x 720cc injectors. The feed is coming from sumped fuel cell, so it needs to be an external inline unit. Any recommendations and model numbers with prices? I was thinking of something like a Walbro GSL392 unit. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted February 10, 2004 Share Posted February 10, 2004 Not too sure on the LPH specs, but how about the MSD unit. I am using it on the LT1. Under $80 from Summit: http://store.summitracing.com/partdetail.asp?part=MSD%2D2225 Quote Link to comment Share on other sites More sharing options...
auxilary Posted February 11, 2004 Author Share Posted February 11, 2004 Thanks tim, but that pump doesn't flow enough for the rotary c'mon guys, doesn't anyone else read this forum? Quote Link to comment Share on other sites More sharing options...
slownrusty Posted February 11, 2004 Share Posted February 11, 2004 I am running the Walboro GSL392, so far its been fantastic and will support up to 600hp on a forced induction motor. Yasin Quote Link to comment Share on other sites More sharing options...
johnc Posted February 11, 2004 Share Posted February 11, 2004 I run the Bosch Porsche pump. Part number is something like: 0.580.254.979. About $225 new and $100 rebuilt. This pump and the Walbro unit do not pull fuel very well. Mount them lower then the fuel cell or put a helper pump in the tank as a feed. Quote Link to comment Share on other sites More sharing options...
auxilary Posted February 11, 2004 Author Share Posted February 11, 2004 Thanks Yasin and John. I can't really put a fuel pump into the cell, no provisioning, so it'll have to be gravity feed. Quote Link to comment Share on other sites More sharing options...
240zprace Posted February 11, 2004 Share Posted February 11, 2004 try the aeromotive one... part# AEI-11101. thispump flows 500lbs./hr. at 12 volts and 45 psi, it can support up to 1000 hp. summit sales it for $289.88 Quote Link to comment Share on other sites More sharing options...
johnc Posted February 12, 2004 Share Posted February 12, 2004 I installed that Aeromotive pump on a customer's car. Its the heaviest damn fuel pump I've ever seen. Must be 10 lbs. And it has -10 AN fittings! Quote Link to comment Share on other sites More sharing options...
Guest 81na ZX Posted February 13, 2004 Share Posted February 13, 2004 If you want 255lph, get the Walbro I've got one in my Talon. You probally know a bunch of guys with them too... The Aeromotive pump is REALLY nice. Loud though, probally a little louder than a Walbro. A friend of mine had one in a SR20DET powered Pulsar. Quote Link to comment Share on other sites More sharing options...
Guest Chris240turbo Posted February 26, 2004 Share Posted February 26, 2004 I run that aeromotive A1000 pump, Johnc is right, it's pretty heavy, and kinda loud, the extruded housing is pretty though! I run a fuel cell, mounted where the spare tire well used to be, and the cell has -10 outlets, so I went -10 from cell to pump, then -10 to -8 adapter to 1/2 hard line, was kind of a pain to plumb, but it works great! Quote Link to comment Share on other sites More sharing options...
