Guest Anubis Posted February 17, 2004 Share Posted February 17, 2004 as the topic say looking for a good one, since B&M didn't have one for the tranny of the 1983 280ZX Turbo. Quote Link to comment Share on other sites More sharing options...
Guest Anubis Posted February 17, 2004 Share Posted February 17, 2004 I was under the impression that a short shifter for the Mustangs with the T5 tranny would work on the 280zxt. I was told diffrently thought. Quote Link to comment Share on other sites More sharing options...
Garrett76Zt Posted February 17, 2004 Share Posted February 17, 2004 Yes they will work, I just bought a B&M Ripper shifter for a mustang T-5/T-45. Bolts right up Quote Link to comment Share on other sites More sharing options...
Phantom Posted February 17, 2004 Share Posted February 17, 2004 MSA has one for the Nissan T-5. NOt sure if it works with the turbo 5-spd. though. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted February 17, 2004 Share Posted February 17, 2004 Phantom said: MSA has one for the Nissan T-5. NOt sure if it works with the turbo 5-spd. though. Nissan T5 is the turbo 5 speed. B&M Ripper for a Mustang T5 bolts right up and is an excellent shifter. You can get them used off eBay sometimes for less than $100. It also compensates a little for the forward position of the tranny in an S30. Quote Link to comment Share on other sites More sharing options...
Guest Paul Felker Posted February 17, 2004 Share Posted February 17, 2004 I used a steeda tri-ax shifter on my z, i LOVE it. if you are on a budget then go on ebay and get a stock mustang shifter, they are cheap and they are a vast improvement over the stock nissan one, i was going to just get a stock mustang shifter off ebay, but when i looked for one there wasnt really too much out there at the time, so i bought the steeda one Quote Link to comment Share on other sites More sharing options...
Guest Anubis Posted February 17, 2004 Share Posted February 17, 2004 ok thanks Anything else you can recommend for the drivetrain? I'm putting the L28ET in a 280Z (if i hadn't mentioned that) Quote Link to comment Share on other sites More sharing options...
speedstylez78 Posted February 18, 2004 Share Posted February 18, 2004 if you dont already have one an r-200 diff does real nice and the t-5 drive shaft bolts up to it, which it wont with a r-180 . Quote Link to comment Share on other sites More sharing options...
Guest Anubis Posted February 18, 2004 Share Posted February 18, 2004 Yea, to be honest, I'm learning as I'm working on this project. I sent Top End an email asking them about rebuilding my L28ET to hold around 350-450hp to the wheels, which I've been told should be no problem for the motor. Any guess on how much it might cost? Or suggestions on going another route? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted February 18, 2004 Share Posted February 18, 2004 Quote Yea' date=' to be honest, I'm learning as I'm working on this project. I sent Top End an email asking them about rebuilding my L28ET to hold around 350-450hp to the wheels, which I've been told should be no problem for the motor. Any guess on how much it might cost? Or suggestions on going another route?[/quote'] You won't find much support for TEP here. Lots of claims and hot air, not much in terms of real performance. 400+ hp is still the cutting edge for a 2.8 liter, although there are a few 3.0 liter L28s running those numbers. Heavily built and expensive engines - think balancing, block, crank and rod prep, forged pistons, ARP hardware, but probably most important is cylinder head prep. Stock will do 400 at the crank; past that is $. Quote Link to comment Share on other sites More sharing options...
