3-wire delco alternator, what do i do with indicator lamp?
Sleeper-Z
The guy who rebuilt my alternator told me some sort of small resistance was needed in this circuit to allow the alternator to work (charge?) correctly. It didn't quite make any sense to me (if bulb burnt out, then alternator quits working?). Anyway, I went back and asked him again about it, and without any specifics he said it does require a bulb or some kind of small resistance.
The light is somewhat useful since it will basically be an idiot light to tell you if something goes wrong with the charging system. The light I got doesn't pull enough juice to excite the alternator, but a blip on the gas does. I wired mine inside the car and drilled a hole in the ashtray for it. I also had to use a diode like Moby since I had run-on problems when I first started out.
Jon
