HELP an oil leak not just an oil leak....
Damn this is going to be long....
So I've got an oil leak on the back side of my engine, it's not coming out of the main seal, futher investigation show it's out of the rear of the intake manifold, (Edelbrock performer RPM). Tear it down put it back together...Fire it, still an oil leak. Buddy comes over... it could be the plug (drivers side UNDER the cylinder head) we pull it down, yank the plug and it's got a galled (sp) thread (the head is off at this point) get new plug, seal it, put 1/2 enging back together over the course of a week. Fired it today and let it idle for 15+ min. NO leak GREAT!!! Take it for a spin, get back to the house and the engine is PISSING oil all over the rear of the block again arrrrrggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh son of a bitchhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.
So enlighten me.
Oh come on, if you know PLEASE ANSWER WHY IT'S DOING THIS TO ME!!!
Here is my thought too much pressure in the crankcase, I've got a PCV in the passenger side valve cover but it's not enough to pull the pressure out to keep the oil from getting past the seal (it's blowing by the front too!!!)
So I've got a set of Moroso breathers I'm about to go and drill the VC to accept right now, so any other thoughts????
David (I'm pissed but sill amused)
BTW I drove a 350Z on Saturday (yawn!!!) sure it handles GREAT but . damn it anin't got nowhere near enough power. I'll keep my 240 until I build my FFR Spyder.
d
I'm not trying to dismiss you but gaskets (ahem) at this point, screw em. (I'm using a thich ass bead of silicone ultra gray on the front end and back end of the intake, AND I let them cure for 48 HRS!!!) It's the ENDS of the intake (F/R), initially that are leaking/seeping) I followed David Vizard book "How to rebuild your small block chevy" and put some sealant on the rubber gaskets... then the other day Grumpyvette posts this:
http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=32460
I'm like HELL YEAH thats the problem...NOPE (after reinstalling the intake manifold) I pull the head, the plug on the drivers side behind the cylinder head, WTF is it there for any way???
After a romping joy ride, OIL, frigging OIL everywhere. I'm about to get 5 gal of gas and set this MF on fire, I'm at the end of my rope, so much work, trying to get it ready for the Branson show/cruise and I'm back at the starting line.
HELP!!!!!!!!
d
Well the reason I was asking if it was pushing them out and not pulling them in,
is because if it was pulling them in that might indicate an intake leak from the
inside from the pan that is on the bottom of the intake.
Can you feel pressure coming out of the oil fill hole in the valve cover? There should
be some but not too much.
Guy
It sounds mightily like you are pressurizing the crankcase, so your new breathers should help. A person can take a prick punch to the block surface where the gasket sits to get more bite... something I've rebuilt had holes in the block surface for tits on the gasket to drop into, and other gaskets have had rails. Drilling holes and a LONG cure time might help with your silicone home made gasket.
Have you ever tried the 'right stuff' gasket making goo in a can? comes out like cheese whiz & stuck well for me to make my own pan gasket. (I did have everything absolutely dry and oil free).
Does the oil pressure sender sit back in that area? I've had them puke all over everything. HTH
I think you have four choices.
1. valve cover
2. intake
3. oil pressure port
4. distributor
It sounds like you did the intake right (thick bead of silicone).
So you need to wash off the oil drive it for a few minutes and get a good look where it is going from.
You should use cork gaskets on the valve covers (rubber sucks)
Make sure you have a gasket under the distributor
Make sure the oil pressure line for the oil pressure port is not leaking.
I had this problem on my truck when I put the engine in. It turned out that when I put the engine in I let it lean back to far and bumped the fitting from the oil pressure guage on the firewall and damaged it so it leaked (alot). It looked just like an intake manifold leak and I almost pulled the intake until I noticed the damaged fitting.
Well,
Good advice from you guys
As far as gaskets:
Both valve covers have cork gaskets, they are the Trick Flow valve covers which have a nice thick flange so they arent leaking.
Distributor has new gasket.
Oil pressure sending unit is screwing in good and has some sealant on it also.
I didn't reuse any gaskets all are brand new. I'm going to drill the VC tonight and probably pull the Oil P sending unit and see what happens next
It's just disheartening when you put so much work into something and you think you have the problem fixed then you find out it's still broke :(
ds
This is a long shot but here it goes... I had an oil leak that drove me nuts (i mean frigging nuts) and it turned out to be the accessory bolt hole on the passenger side of the 350. The top one goes clear threw to the stock location of the fuel pump. At idle it wont pump oil..only till 2500-3000 rmps. I know u said intake but i was thinking maybe the fan was pushing the oil up there, i know with my motor it got everywhere till i plugged it with a short bolt.
Not all sbc have this accessory hole going into the stock fuel pump area.
72Zcar
Oh, Oh, Oh
I already fixed that one, my buddy told me about it yup, it was leaking. The reason I "think" it's internal pressure is because it's seeping oil past the FRONT galley plug, just a little bit, a very little bit but it's there.
David
dsommer i don't know where i read this, it may have been on this site, but it worked for me. with the intake off use a punch to make several small indentions on the edge of the block before putting your gasket material on you might also make the indentions on the intake manifold it gives the gasket material something to "bite".it worked for me hope it helps rick
