240 stub axles in a 280 - Tech Note
Jersey
This I'm sure is the correct answer!
[The spacers] are there to prevent side forces on the ball
bearings just as you surmise. They do this with a
slight preload on the inner races. Being loose is very
bad in this application. The inner races are slightly
preloaded but the bearings and outer races are not.
There are two bearings there just to accomplish this
task, one would likely suffice for simple load bearing
functions. Like in a solid axle design.
If you used too small of a spacer, things would move
around and the bearing would fail from misalignment
because the inner race would be drawn out of true to
the outer race. If you use too long of a spacer, the
races would again be drawn out of alignment or the
outer race would wobble out of position and things
would wear very quickly.
So the spacers are there to PREVENT preload, and I'm sure the drag test is a measure of how much preload is present and if it is low enough to be within acceptable limits.
This is also evident in John's FSM excerpt: 3.9 in lbs preload is basically like taking your pinky and pushing on the inner race on both sides. It's just enough to take out the slop in the ball bearing, but not enough to make the ball bearings wear too quickly.
Jon
  • 2 years later...
How do you preload a ball bearing? If you push or pull on the center in relation to the outer race, that would just make it wear really fast, right? No preload on tranny bearings, or any sealed unit bearings used in front hubs that I'm aware of. I can't think of a single ball bearing that gets used as a straight axle wheel bearing that gets any type of preload.
I'm not exactly the bearing guru, but I've been around a few and sold a few in the past couple years... just never heard of bearing preload on a ball bearing.
Jon
Well i know a few types of BB that can take axial pre-load but only small amounts (about 10% of radial), they are 'Deep groove BB' either in single or double rows' also thrust collar BB take pre load when used in a positioning requirement.
nato,
just thought id share, think this thread is like 3 years old!!!!:rolleyesg
