BayAreaZT Posted April 29, 2004 Share Posted April 29, 2004 I'm running the 240mm ACT street disc and heavy duty pressure plate in my turbo 240. I'm might be pulling my motor soon to have it rebuilt since I just scored a complete spare L28ET for $250 . Does anyone know any alternative pressure plates I can use with the street disc? If I put in a stock turbo pressure plate will that defeat the purpose of using the ACT street disc? I guess I want something not quite as stiff and will allow me to lower the clutch pedel without swapping master or slave cylinders while retaining above stock holding power (I want it all ). Just looking into possible alternatives since I will be pulling the motor soon. Quote Link to comment Share on other sites More sharing options...
fl327 Posted April 29, 2004 Share Posted April 29, 2004 Maybe use a spec pressure plate? not running a puck clutch but hasnt slipped on me at 12psi+ and feels lighter than a factory turbo clutch. Or maybe that z31 pressure plate? Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted April 29, 2004 Author Share Posted April 29, 2004 Is the Z31 PP any stronger than the 280ZX turbo PP and does it bolt up to the 240mm flywheel? Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted April 29, 2004 Share Posted April 29, 2004 Okay now I'm really confused. Is it better to have the stronger disk and a stock pressure plate? Or better to have a stock disk and stronger pressure plate?? I ended up opting for the performance PP and stock type disk, as I figure the clamping power really is in the PP... and the ACT 6 puck metallic clutch I was using before chewed everything up pretty bad. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 30, 2004 Share Posted April 30, 2004 Either will work, but it will be less grabby and easier to drive and won't wear into the pp or the flywheel and still hold the power (to a point) with the strong pp and stock disk. Jon Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted April 30, 2004 Share Posted April 30, 2004 yeah I really want to spread the word to anyone who doesn't know, the ACT or other metallic multi puck clutches REALLY wear into your flywheel and pressure plate... I dont think I'll ever use another one again... and anyways... I'll be very glad to have a near-stock feeling pedal again and no damn chatter. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted April 30, 2004 Share Posted April 30, 2004 yeah I really want to spread the word to anyone who doesn't know, the ACT or other metallic multi puck clutches REALLY wear into your flywheel and pressure plate... Kind of like running chrome moly rings versus iron rings, trade offs come with everything. So when it wears out, buy another clutch kit with disc and pp and go to the junkyard and get another $20 240mm pathfinder flywheel. Now if you spend big bucks on a lightened flywheel and it gets ate up, that could cause some distress. Let us know how your new clutch setup works out when you get back up and running. Quote Link to comment Share on other sites More sharing options...
Pyro Posted May 3, 2004 Share Posted May 3, 2004 I'm using the stock nissan 2+2 pressure plate and a 6 puck, Spec, ceramic, sprung hub, clutch (stage 3). 12 psi of boost and no problem with slippage so far. However, the chatter kind of sucks but the pedal is soft. Next time I will try the Spec Kevlar clutch (stage 2, chatter free) with the spec pressure plate. Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted May 3, 2004 Author Share Posted May 3, 2004 I think I may try the stock turbo pressure plate for a while. If it doesn't work out I can always switch back to the ACT since I will be pulling the motor again after the rebuild. Quote Link to comment Share on other sites More sharing options...
turbobluestreak Posted May 3, 2004 Share Posted May 3, 2004 guys my ACT performance disc, and Heavy duty PP is starting to slip at 13psi and I'm getting mad . Is there anything better then ACT to run on a turbo 280zx? tbs Quote Link to comment Share on other sites More sharing options...
Pyro Posted May 3, 2004 Share Posted May 3, 2004 Go to NipponPower.com they sell ACT, Spec, and Center force for Z's. The SPEC kits come in 5 levels of performance which range in torque holding capacity of 395 ft lbs to 600 ft lbs. Quote Link to comment Share on other sites More sharing options...
