RB26DETT mounts for Z (searched)
Guest Nameless EJ6
Guest Nameless EJ6
Are there any companies or members here that can custom make mounts for putting the RB26DETT into the elder Z cars? Specifically the 240z?
I'm new to the Z stuff. I was originally planning on putting my RB26DETT into a 240sx, but there's just something sexual about an older Z that grabs my attention, so I may sway that direction depending on options and pricing.
I did search about the mounts, but there are so many threads and I don't want to dig through them to find something simple.
I appologize if this makes anyone mad - I'm sure it's been asked a billion times. Thanks for the help.
BTW: My engine is ready to drop ('98 RB26DETT/RB25DET gearbox), just trying to decide on the car. :)
Guest 81na ZX
also.... does the rb25 require the same oilpan modifications as the rb26?
Yes. he only RB engine that doesn't need the modifications are the RB20DET's out of the z31
if so where is a good place to find those parts?
Either fab them yourself or Nissan Japan/Australia/or NZ (Pan and pickup from a z31 200zr)
Yeah, those are my mounts on eBay. I'm going to be making some more soon, so if anyone wants some, let me know. I have one set left right now. I sell them direct and on eBay.
If anyone needs more info on oilpan conversions for a Z, you can also check out McKinney Motorsports in California http://www.mckinneymotorsports.com
Rick
Guest zline
custom
pretty easy to make.
i usualy just make a tubular tranny xmember that doubles as a brace for the trans tunnel and mount
You still need the rb20 Z-31 oil pan and oil pickup.... but it does not need the same mods the rb26 block needs. everything bolts up.
  • 2 months later...
are you getting the z31 rb20 mounts for that price, or a set of custom made units?
the units mentioned above a CNC'd pieces and are very good looking :D they also set the motor back and as low as possible so a custom driveshaft will be needed. I will be getting a set as soon as i can find someone that still has them for sale. with my new motor and powerglide combo i will need a new drivesahft, downpipe and intercooler pipe anyways.
Since you are in aus maybe just call them they take forever to reply. i bought my powerglide adapter thru them.
Aks if the mounts set the motor to the rear and as low as possible. or if the just dupicated the z31 rb mounts.
thanks
Stony
