AZC chromoly A-arms FS
Ok not really listing these yet just curious if anyone would be interested in front suspension on my car?
I have the AZC coilover conversion along with AZC chromoly a-arms and TC rods. the struts were sectioned and i used the lower halve of a z31 r lug setup with z32 calipers. with the control arms i was able to adjust everything out so everything aligned up right to stock specs. Here is the catch i had to modify the tierof length because the z31 knuckles were differnt. I had a pro weld in some cromoly to lengthen the rods. What does this mean? the entire front suspension HAS to go as a set. anyone interested. What do you think it's worth?
Stony
Considering the AZC suspension stuff alone goes for $600, I'd think you should get at least 1200 for the suspension.
That might be a really good set up for a prepared autoxer or track day type car. Looks like the steering knuckles are designed for Ackerman, big brakes with off the shelf parts, coilovers, etc. Looks pretty sweet.
Jon
