BobsZTwins Posted June 5, 2004 Share Posted June 5, 2004 The turbo'd 350 in my 74 is getting pretty tired (low compression on 2 cyl, puffs of blue on hot starts, way down on power) so I'm weighing whether to rebuild or replace with something different I found this 355 SBC on eBay and would really appreciate any opinions on value & potential HP: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2480295528 Thanks!![/url] Quote Link to comment Share on other sites More sharing options...
DaleMX Posted June 6, 2004 Share Posted June 6, 2004 I wouldn't do it. It seems like too much money for something on EBay. For one thing the guy wants you to use Mobile 1 at break in (just sounds fishy). It might be a good deal, but Mr. Goodwrench has the ZZ383 with a factory guarentee. http://www.sdpc2000.com/cart.asp?action=prod_detail&catid=120&pid=156334 Dale Quote Link to comment Share on other sites More sharing options...
Guest plainswolf Posted June 6, 2004 Share Posted June 6, 2004 I have always heard that an engine should be broken in with regular oil...not synthetic, otherwise it may not break in properly. once the engine is broken in, or at least the cam is broken in, THEN use sythetic oil in it. You guys probably know alot more than me about this. But I would use regular oil till the engine had a good 1-1500 miles on it or so before I switched to synthetic. Grumpy?? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted June 6, 2004 Share Posted June 6, 2004 I'm with Dale on this one. For that kind of $$$ I would get something that has some kind of warranty behind it and a place that I can go to and complain to a person if something is bad..... Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted June 6, 2004 Share Posted June 6, 2004 I would not touch it! To much money for the returns. You could buy a LS1/tranny combo for less. 383 sbc? ZZ4? Mike Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted June 6, 2004 Share Posted June 6, 2004 yep, for that money get something already broke in, with a dynosheet and a warrantee. Quote Link to comment Share on other sites More sharing options...
BobsZTwins Posted June 7, 2004 Author Share Posted June 7, 2004 Thanks for the feedback. I think I'm going to do a teardown on my current setup, take all the bits to a good local machine shop and either have mine rebuilt (if the block checks out OK) or start fresh. I've been pricing all the main bits from Summit, Jegs, PAW, etc. It looks like PAW has some good packages and pricing to start from. I haven't made up my mind whether to stick with the single turbo or go for a higher compression non-boosted setup. If the crank isn't up to snuff, I'll probably go with a stroker kit. Like the old adage says "there's no substitute for cubic inches." Quote Link to comment Share on other sites More sharing options...
