Stripped Crankshaft/ flywheel
Maybe use some Helicoil thread inserts. You will drill the current holes a little oversize and tap with a special tap. Then you thread the special insert in with a special tool and are set. The process isn't too bad and doesn't cost too much either.
Guest 77vegasz
There is a solid heavy duty thread insert called a Keensert. They are available from McMaster carr. They install in the same method as a Helicoil, but are for heavy duty applications.
Jon
Heh same thing happend to me about two weeks ago i managed to strip two out of six hooles and afther trying few things i just got right size tap ( 12x1.25 i belive if interested i can check for sure) and in it went with no problem. it took some patience and time for sure but very very simple to do.
Ivan
